[Mapbender-users] HTML-Legend in Mapbender 2.7
Patrick Meis Meis at stadt-muenster.de
Fri Apr 26 02:32:18 PDT 2019
Hello Armin,
thanks for your help.
And you are right, I should present a more extensive description of my problem.
I have a raster layer of the german "Flächennutzungsplan", a raster layer. Which has a rather big Legend in Pdf-format:
https://geo.stadt-muenster.de/webgis2/html/fnp/legende_fnp.pdf
I would like to create a link to this Pdf in my Mapbender legend.
Something like shown here:
http://demo.mapserver.org/cgi-bin/mapserv?map=%2Fosgeo%2Fmapserver%2Fitasca_legend%2Fmap%2Fitasca3.map&layers=all&zoomsize=2&zoomdir=1&map_size=600+400&map_web=
(for example the Airport-link leads tot he Pdf).
But i am not sure if Mapbender can work with a legend sent in HTML and not in Png.
Patrick
-----Ursprüngliche Nachricht-----
Von: Armin Retterath [mailto:armin.retterath at vermkv.rlp.de]
Gesendet: Freitag, 26. April 2019 10:23
An: Mapbender User List; Patrick Meis
Betreff: Re: [Mapbender-users] HTML-Legend in Mapbender 2.7
[DOI-Mail]:
Diese Mail haben Sie über das Behördennetz DOI erhalten.
hi pascal,
can you check if the legend handling like in
http://www.geoportal.rlp.de/portal/karten.html (mapbender 2.x trunk)
is that what you want? you can define legends in mapserver for raster and vector data. mapbender calls the legendurl (mapserver set this to a getlegendgraphic url !) by every getmap invocation. therefor the legend shows only the vector layers, that are visible. the raster legend is hardcoded.
maybe you can give some more info about you demands ;-)
best regards
armin
> Patrick Meis <Meis at stadt-muenster.de> hat am 26. April 2019 um 09:49 geschrieben:
> Von: Patrick Meis
> Gesendet: Donnerstag, 25. April 2019 11:14
> An: Mapbender_users
> Betreff: HTML-Legend in Mapbender 2.7
> Hello group,
> is it possible to use a HTML-legend for a WMS in Mapbender 2.7, as described in the documentation for Mapserver:
> https://mapserver.org/de/output/html_legend.html#html-legend
> Im not able to find any examples for it in the web, but i did find an old Email in this group that it was not possible in 2008:
> https://lists.osgeo.org/pipermail/mapbender_users/2008-April/002003.html (only in german)
> Maybe something changed? Does anybody know?
> Thanks for any help
> Patrick
> diesmalw?hleich.eu<https://www.diesmalwaehleich.eu>
> Am 26. Mai 2019 ist Europawahl
> Der Schutz Ihrer personenbezogenen Daten ist der Stadt M?nster ein wichtiges Anliegen. Die Datenschutzerkl?rung finden Sie unter folgendem Link: https://www.stadt-muenster.de/datenschutz.html
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
diesmalwähleich.eu<https://www.diesmalwaehleich.eu>
Der Schutz Ihrer personenbezogenen Daten ist der Stadt Münster ein wichtiges Anliegen. Die Datenschutzerklärung finden Sie unter folgendem Link: https://www.stadt-muenster.de/datenschutz.html
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20190426/36d6e09d/attachment-0001.html>
More information about the Mapbender_users mailing list
