[Mapbender-users] HTML-Legend in Mapbender 2.7
Armin Retterath
armin.retterath at vermkv.rlp.de
Fri Apr 26 02:58:29 PDT 2019
hi pascal,
it is not yet implemented - but it should not be to difficult ;-) - maybe 1 hour ?
https://trac.osgeo.org/mapbender/browser/trunk/mapbender/http/javascripts/mod_legendDiv.php
maybe some further objects should be extended - in our database there are no legendurl elements with pdf or html mimetypes ;-)
(1400 services registrated)
by when do you need this little feature?
i extended the map/layer object last week for couplings between layers and featuretypes and i think i remember where to fix it.
best regards
armin
> Patrick Meis <Meis at stadt-muenster.de> hat am 26. April 2019 um 11:32 geschrieben:
> Hello Armin,
> thanks for your help.
> And you are right, I should present a more extensive description of my problem.
> I have a raster layer of the german "Flächennutzungsplan", a raster layer. Which has a rather big Legend in Pdf-format:
> https://geo.stadt-muenster.de/webgis2/html/fnp/legende_fnp.pdf
> I would like to create a link to this Pdf in my Mapbender legend.
> Something like shown here:
> http://demo.mapserver.org/cgi-bin/mapserv?map=%2Fosgeo%2Fmapserver%2Fitasca_legend%2Fmap%2Fitasca3.map&layers=all&zoomsize=2&zoomdir=1&map_size=600+400&map_web=
> (for example the Airport-link leads tot he Pdf).
> But i am not sure if Mapbender can work with a legend sent in HTML and not in Png.
> Patrick
> -----Ursprüngliche Nachricht-----
> Von: Armin Retterath [mailto:armin.retterath at vermkv.rlp.de]
> Gesendet: Freitag, 26. April 2019 10:23
> An: Mapbender User List; Patrick Meis
> Betreff: Re: [Mapbender-users] HTML-Legend in Mapbender 2.7
> [DOI-Mail]:
> Diese Mail haben Sie über das Behördennetz DOI erhalten.
> hi pascal,
> can you check if the legend handling like in
> http://www.geoportal.rlp.de/portal/karten.html (mapbender 2.x trunk)
> is that what you want? you can define legends in mapserver for raster and vector data. mapbender calls the legendurl (mapserver set this to a getlegendgraphic url !) by every getmap invocation. therefor the legend shows only the vector layers, that are visible. the raster legend is hardcoded.
> maybe you can give some more info about you demands ;-)
> best regards
> armin
> > Patrick Meis <Meis at stadt-muenster.de> hat am 26. April 2019 um 09:49 geschrieben:
> > Von: Patrick Meis
> > Gesendet: Donnerstag, 25. April 2019 11:14
> > An: Mapbender_users
> > Betreff: HTML-Legend in Mapbender 2.7
> > Hello group,
> > is it possible to use a HTML-legend for a WMS in Mapbender 2.7, as described in the documentation for Mapserver:
> > https://mapserver.org/de/output/html_legend.html#html-legend
> > Im not able to find any examples for it in the web, but i did find an old Email in this group that it was not possible in 2008:
> > https://lists.osgeo.org/pipermail/mapbender_users/2008-April/002003.html (only in german)
> > Maybe something changed? Does anybody know?
> > Thanks for any help
> > Patrick
> > diesmalw?hleich.eu<https://www.diesmalwaehleich.eu>
> > Am 26. Mai 2019 ist Europawahl
> > Der Schutz Ihrer personenbezogenen Daten ist der Stadt M?nster ein wichtiges Anliegen. Die Datenschutzerkl?rung finden Sie unter folgendem Link: https://www.stadt-muenster.de/datenschutz.html
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/mapbender_users
> diesmalwähleich.eu<https://www.diesmalwaehleich.eu>
> Der Schutz Ihrer personenbezogenen Daten ist der Stadt Münster ein wichtiges Anliegen. Die Datenschutzerklärung finden Sie unter folgendem Link: https://www.stadt-muenster.de/datenschutz.html
More information about the Mapbender_users
