[Mapbender-users] How do you change the basemap source in MapBender?Getting Internal Error for the basic
Gagan Gowda
gagan.manjunatha_gowda at dfki.de
Mon Jun 3 06:35:01 PDT 2019
Hi Jörg,
I did reply to the list. You can see my response in blue from the
previous mail. To be more specific I am not using apache server now,
rather I am using Symfony built-in server. As I said previously I don't
see any error message in symphony logs. Please find the screenshot
attached. I just get a blank screen.
I am trying to follow the documentation, however, I feel, I am not going
in the right direction. My goal is to build the digitizer with a change
of logo and base map view. Please guide me how do I proceed with this
setup. I tried telling you the process which I followed also in my
previous mail, but I had no luck. This tool is really an important
aspect of our research requirement, so need your guidance.
Waiting for your reply :)
Thanks & Best Regards
On 2019-06-03 10:26, Jörg Thomsen wrote:
> Hi Gagan,
> it's better to answer to the list.
> error 500 ist evil :)
> Please have a look into the apache error.log, that should give us some
> hints.
> Jörg
> Am 31.05.19 um 13:10 schrieb Gagan Gowda:
>> Hello Jörg,
>> Thanks for your reply. Please find the details of how I downloaded
>> and configured Mapbender.
>> 1. Downloaded the git repository from
>> https://github.com/mapbender/mapbender-starter [1]. (successfully
>> installed all the dependencies)
>> 2. Started the server using the command: CD APPLICATION and then
>> running APP/CONSOLE SERVER:RUN
>> 3. Later I configured Mapbender following this link:
>> https://doc.mapbender.org/en/installation/configuration.html [2]
>> 4. Later tried following the Quickstart tutorial, where in I am
>> getting an error in developer mode:
>> (http://localhost/mapbender3/app_dev.php [3])
>> I get the error as Page not found. The mapbender server is running
>> at http://127.0.0.1/8080 [4]
>> However when I try running the server it opens up the application
>> page, where I tried following the quick tutorial (not in app_dev).
>> Just clicking on one of the view button of the application. Eg:
>> http://127.0.0.1/application/mapbender_user_yml [5] (I get the
>> components but not the map view)
>>> DO YOU SEE ANY ERROR-MSG IN THE BROWSER?
>> The error message from the browser is as follows:
>> Failed to load resource: the server responded with a status of 500
>> (Internal Server Error) js:432
>> Mapbender Info: Load application's configuration: Internal Server
>> Error
>>> IS THE PRE-INSTALLED APPLICATION WORKING FINE?
>> Only the mobile applications work fine, the other application
>> reports 500 Internal Server Error.
>>> can you give us access to the capabilites of your geoserver-wms?
>> I have the capabilites in localhost.
>>> are there any hints in the log?
>> Please find the screenshot from symphony profiler. Couldnt find any
>> error message for the 500 Internal Server error.
>> When adding the basemap through Geoserver I get no errors in
>> symphony. (I tried removing the basemap source: osm demo) and added
>> my geoserver WMS instance. But doesnt seem to work.
>>> ARE YOU ABLE TO LOAD THE WMS INTO A DESKTOP-GIS?
>> Yes I can load the WMS in my QGIS desktop.
>> Please let me know if I am doing write, as i am new to this.
>> Thanks
>> On 2019-05-28 17:02, Jörg Thomsen wrote:
>>> Hi,
>>> if the quickstart-examples don't work it's difficult to help. You
>> should
>>> give some more information:
>>> - do you see any error-msg in the browser?
>>> - is the pre-installed application working fine?
>>> - can you give us access to the capabilites of your geoserver-wms?
>>> - are there any hints in the log?
>>> - have you tried using app_dev.php instead of app.php and what are
>> the
>>> error-messages (in browser and dev.log??
>>> - are you able to load the wms into a desktop-GIS?
>>> Jörg
>>> Am 28.05.19 um 14:32 schrieb Gagan Gowda:
>>>> Hello,
>>>> I am new to Mapbender and I want to build a simple
>> geoportal for
>>>> maintaining polygon information drawn on the map. So I assume I
>> need
>>>> components like Digitizer and database linked to it. Similar to
>> demo
>>>> digitizer seen here:
>>>> https://demo.mapbender.org/application/mapbender_user_digitizer
>> [6]
>>>> By default when I try to mirror the application and try opening
>> it, I
>>>> get Internal error message and the base map does not open. So I
>> wanted
>>>> to change the base map source to the one working from my
>> GeoServer. For
>>>> the base map, by default, the source is from OSM Demo(osm). I
>> tried
>>>> using WMS source from GeoServer but somehow I don't get any
>> output.
>>>> I did follow this link"
> https://doc.mapbender.org/en/quickstart.html#loading-web-map-services
>> [7].
>>>> But not working in mine
>>>> How do I change the Basemap source from Geoserver or any WMS
>> source? Can
>>>> you give me any working example, please
>>> Viele Grüße,
>>> Jörg Thomsen
>>> Kompaktkurs Aufbau einer GDI mit Open-Source-Software
>>> FOSS Academy Sommerschule: 23. bis 27. September 2019
>>> https://www.foss-academy.com/kompaktkurse.html [8]
>>> Jörg Thomsen
>>> WhereGroup GmbH & Co. KG
>>> Gillweg 3
>>> 14193 Berlin
>>> Germany
>>> Fon: +49 (0)30 / 5130 278 74
>>> Fax: +49 (0)30 / 89 09 53 21
>>> joerg.thomsen at wheregroup.com
>>> www.wheregroup.com [9]
>>> Amtsgericht Bonn, HRA 6788
>>> Komplementärin:
>>> WhereGroup Verwaltungs GmbH
>>> vertreten durch:
>>> Olaf Knopp, Peter Stamm
>>> Folgen Sie der WhereGroup auf twitter:
>> http://twitter.com/WhereGroup_com [10]
>> Thanks & Best Regards,
>> Gagan M Gowda
>> Software Engineer
>> Deutsches Forschungszentrum für Künstliche Intelligenz GmbH
>> Firmensitz: Trippstadter Strasse 122, D-67663 Kaiserslautern
> Viele Grüße,
> Jörg Thomsen
> Jörg Thomsen
> Gillweg 3
> 14193 Berlin
> Germany
> Komplementärin:
> vertreten durch:
> Links:
> [1] https://github.com/mapbender/mapbender-starter
> [2] https://doc.mapbender.org/en/installation/configuration.html
> [3] http://localhost/mapbender3/app_dev.php
> [4] http://127.0.0.1/8080
> [5] http://127.0.0.1/application/mapbender_user_yml
> [6] https://demo.mapbender.org/application/mapbender_user_digitizer
> [7]
> [8] https://www.foss-academy.com/kompaktkurse.html
> [9] http://www.wheregroup.com
> [10] http://twitter.com/WhereGroup_com
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Gagan M Gowda
Software Engineer
Name: Screen Shot 2019-06-03 at 3.18.23 PM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20190603/d71e4d9b/attachment-0001.png>
More information about the Mapbender_users
