[Mapbender-users] How do you change the basemap source in MapBender?Getting Internal Error for the basic
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Mon Jun 3 01:26:14 PDT 2019
Hi Gagan,
it's better to answer to the list.
error 500 ist evil :)
Please have a look into the apache error.log, that should give us some
hints.
Jörg
Am 31.05.19 um 13:10 schrieb Gagan Gowda:
> Hello Jörg,
> Thanks for your reply. Please find the details of how I downloaded and configured Mapbender.
> 1. Downloaded the git repository from https://github.com/mapbender/mapbender-starter. (successfully installed all the dependencies)
> 2. Started the server using the command: *cd application* and then running *app/console**server:run***3. Later I configured Mapbender following this link:
> https://doc.mapbender.org/en/installation/configuration.html 4. Later
> tried following the Quickstart tutorial, where in I am getting an
> error in developer mode: (http://localhost/mapbender3/app_dev.php) I
> get the error as Page not found. The mapbender server is running at
> http://127.0.0.1/8080
> However when I try running the server it opens up the application page, where I tried following the quick tutorial (not in app_dev).
> Just clicking on one of the view button of the application. Eg: http://127.0.0.1/application/mapbender_user_yml (I get the components but not the map view)
> *>do you see any error-msg in the browser?*
> The error message from the browser is as follows:
> Failed to load resource: the server responded with a status of 500
> (Internal Server Error) js:432
> Mapbender Info: Load application's configuration: Internal Server Error
> >*is the pre-installed application working fine?*
> Only the mobile applications work fine, the other application reports
> 500 Internal Server Error.
> > *can you give us access to the capabilites of your geoserver-wms? *I have the capabilites in localhost*. > are there any hints in the
> log? *Please find the screenshot from symphony profiler. Couldnt find
> any error message for the 500 Internal Server error. When adding the
> basemap through Geoserver I get no errors in symphony. (I tried
> removing the basemap source: osm demo) and added my geoserver WMS
> instance. But doesnt seem to work. > *are you able to load the wms into a desktop-GIS?*
> Yes I can load the WMS in my QGIS desktop. Please let me know if I am
> doing write, as i am new to this. Thanks
> On 2019-05-28 17:02, Jörg Thomsen wrote:
> > Hi,
> > if the quickstart-examples don't work it's difficult to help. You should
> > give some more information:
> > - do you see any error-msg in the browser?
> > - is the pre-installed application working fine?
> > - can you give us access to the capabilites of your geoserver-wms?
> > - are there any hints in the log?
> > - have you tried using app_dev.php instead of app.php and what are the
> > error-messages (in browser and dev.log??
> > - are you able to load the wms into a desktop-GIS?
> > Jörg
> > Am 28.05.19 um 14:32 schrieb Gagan Gowda:
> >> Hello,
> >> I am new to Mapbender and I want to build a simple geoportal for
> >> maintaining polygon information drawn on the map. So I assume I need
> >> components like Digitizer and database linked to it. Similar to demo
> >> digitizer seen here:
> >> https://demo.mapbender.org/application/mapbender_user_digitizer
> >> By default when I try to mirror the application and try opening it, I
> >> get Internal error message and the base map does not open. So I wanted
> >> to change the base map source to the one working from my GeoServer. For
> >> the base map, by default, the source is from OSM Demo(osm). I tried
> >> using WMS source from GeoServer but somehow I don't get any output.
> >> I did follow this link"
> >> https://doc.mapbender.org/en/quickstart.html#loading-web-map-services.
> >> But not working in mine
> >> How do I change the Basemap source from Geoserver or any WMS source? Can
> >> you give me any working example, please
> > Viele Grüße,
> > Jörg Thomsen
> > Kompaktkurs Aufbau einer GDI mit Open-Source-Software
> > FOSS Academy Sommerschule: 23. bis 27. September 2019
> > https://www.foss-academy.com/kompaktkurse.html
> > Jörg Thomsen
> > WhereGroup GmbH & Co. KG
> > Gillweg 3
> > 14193 Berlin
> > Germany
> > Fon: +49 (0)30 / 5130 278 74
> > Fax: +49 (0)30 / 89 09 53 21
> > www.wheregroup.com
> > Amtsgericht Bonn, HRA 6788
> > Komplementärin:
> > WhereGroup Verwaltungs GmbH
> > vertreten durch:
> > Olaf Knopp, Peter Stamm
> > Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> Thanks & Best Regards,
> Gagan M Gowda
> Software Engineer
> Deutsches Forschungszentrum für Künstliche Intelligenz GmbH
> Firmensitz: Trippstadter Strasse 122, D-67663 Kaiserslautern
Viele Grüße,
Jörg Thomsen
Jörg Thomsen
Gillweg 3
14193 Berlin
Germany
www.wheregroup.com
Komplementärin:
vertreten durch:
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20190603/76d16d79/attachment.html>
More information about the Mapbender_users
