[Mapbender-users] import / export of MapBender App Error between versions
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Tue Mar 26 23:36:05 PDT 2019
Am 2019-03-26 18:21, schrieb karsten:
> Hi all,
> I did export an MapBender Application from version 3.0.5.3 and then
> tried to import to a new MapBender installation on teh same machine
> version 3.0.7.7
> (both on windows). It works to import the yml or Json export files and
> I can see the new app in the administration interface . However when
> opening the application on the web itself the layer tree does not
> display and I get an error shown that says something along the lines
> of 'element with ID 252 map.(something) did not initialize correctly'.
> I had the suspicion that the corrupted element is a map or overview
> map element so tried to deleted those and recreated them but that
> brought even more trouble with other elements depending on those. So I
> reverted back to a backup of the app...
> How would I be able to fix this and get the app to display in teh new
> MB version (short of rebuilding it once more) ?
> Note that the mapbender3 management database I am using was was
> generated for this new MB version (and is not the once from the old
> version)
> Cheers
> Karsten Vennemann
Hello Karsten,
Mapbender 3.0.5.3 is quite old ;) Release date: 04.02.2016
https://doc.mapbender.org/en/versions.html
Best way is to update an existing Mapbender installation instead of
copying an application.
Have a look: https://doc.mapbender.org/en/installation/update.html
Maybe for your workflow it could work:
* copy & import your application
* open map-Element and check the selected layersets -> save it
* open layertree -> save it
-> we had some changed concerning layersets, so maybe the element has to
save the new configuration.
Best regards
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
