[Mapbender-users] update mapbender installation on windows errors
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Mar 27 05:16:47 PDT 2019
Very kindly, I ask for you not send cross-post your same message to
multiple lists at once.
-jeff
On 2019-03-27 5:44 AM, karsten wrote:
> Sorry I saw that the windows command are listed below the linux one on that
> webpage, it is
> php.exe app/console doctrine:schema:update --dump-sql
> However when I run that ond e.g. I get the error:
> The program can't start because php7ts.dll is missing from your computer.
> Try reinstalling the program to fix this problem.
> Any hints what is wrong and how to fix this ?
> Cheers
> Karsten
> -----Original Message-----
> From: karsten [mailto:karsten at terragis.net]
> Sent: Wednesday, March 27, 2019 09:37
> To: 'Mapbender User List'
> Subject: update mapbender installation on windows errors
> Hi All,
> When trying to go update a mapbender installation via the commands from
> https://doc.mapbender.org/en/installation/update.html
> I noticed that the commands for the database update work on linux however I
> am having trouble on windows.
> On windows the command
> app/console doctrine:schema:update --dump-sql for example I get this error:
> 'app' is not recognized as an internal or external command, WQhen I add the
> complete windows path like
> c:\ms4w\apps\mapbender3-starter-3.0.7.7\app\console ...
> the erropr is the ame.
> How can I sucessfully run that command on windows ?
> Cheers
> Karsten
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
More information about the Mapbender_users mailing list
