[Mapbender-users] update mapbender installation on windows errors
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Fri Mar 29 03:52:06 PDT 2019
Hello,
Jeff made a pull request and added the information to the documentation
https://github.com/mapbender/mapbender-documentation/pull/60
Thanks Jeff for adding the information to the documentation.
It will be available on https://doc.mapbender.org  when release 3.0.8 is
there.
Solution is to pass the location of the extension in the command:
php -d extension=C:\ms4w\Apache\php\ext\php_pdo_pgsql.dll app/console
doctrine:schema:update --dump-sql
Astrid
Am 2019-03-27 13:16, schrieb Jeff McKenna:
> Very kindly, I ask for you not send cross-post your same message to
> multiple lists at once.
> -jeff
> On 2019-03-27 5:44 AM, karsten wrote:
>> Sorry I saw that the windows command are listed below the linux one on
>> that
>> webpage, it is
>> php.exe app/console doctrine:schema:update --dump-sql
>> However when I run that ond e.g. I get the error:
>> The program can't start because php7ts.dll is missing from your
>> computer.
>> Try reinstalling the program to fix this problem.
>> Any hints what is wrong and how to fix this ?
>> Cheers
>> Karsten
>> -----Original Message-----
>> From: karsten [mailto:karsten at terragis.net]
>> Sent: Wednesday, March 27, 2019 09:37
>> To: 'Mapbender User List'
>> Subject: update mapbender installation on windows errors
>> Hi All,
>> When trying to go update a mapbender installation via the commands
>> from
>> https://doc.mapbender.org/en/installation/update.html
>> I noticed that the commands for the database update work on linux
>> however I
>> am having trouble on windows.
>> On windows the command
>> app/console doctrine:schema:update --dump-sql for example I get this
>> error:
>> 'app' is not recognized as an internal or external command, WQhen I
>> add the
>> complete windows path like
>> c:\ms4w\apps\mapbender3-starter-3.0.7.7\app\console ...
>> the erropr is the ame.
>> How can I sucessfully run that command on windows ?
>> Cheers
>> Karsten
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH & Co.KG
   Eifelstraße 7
   53119 Bonn
   Germany
   Fon: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
