[Mapbender-users] Please help - refreshLayersAfterFeatureSave -
Gal Zsolt zsolt.gal at satelitnt.com
Mon Nov 11 01:22:18 PST 2019
Thank you for your detailed answer.
Astrid wrote an answer and first I need to upgrade Mapbender and Digitizer . I use 3.0.7.3 .
Have a nice day!
On 11 November 2019 at 10:13:30 +02:00, Charlotte Toma (WhereGroup) <charlotte.toma at wheregroup.com> wrote:
> Good morning,
> if you add the "refreshLayersAfterFeatureSave" parameter in your digititizer schemes you don't need to pan/zoom in the map. The moment you klick the save button all listed layers will be updated, e.g. layerinstance 164.
> You need to add this parameter in the same level with "allowDigitize/allowDelete/alllowEditData":
> poi:
> label: point digitizing
> inlineSearch: true
> maxResults: 500
> featureType:
> connection: search_db
> table: poi
> uniqueId: gid
> geomType: point
> geomField: geom
> srid: 4326
> openFormAfterEdit: true
> zoomScaleDenominator: 500
> allowEditData: true
> allowDelete: true
> refreshLayersAfterFeatureSave: - 164
> Greetings
> Charly
> Where2B Konferenz 2019
> 12. Dezember 2019 in Bonn
> where2b-conference.com
> Charlotte Toma
> GIS-Consultant
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49 (0)228 / 90 90 38 - 24
> Fax: +49 (0)228 / 90 90 38 - 11
> <info at wheregroup.com>
> <http://www.wheregroup.com>
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Am 11.11.19 um 06:26 schrieb Gal Zsolt:
> > Hello List!
> > I have a layer MyLines from my Geoserver on the main map. MyLines is a table in a PostgresSQL database.
> > I edit MyLines with Digitizer, and change the field LineColor.
> > The change effect appear only after I pan or zoom on the map.
> > I use
> > - 164
> > where 164 is the Instance-ID of my layer.
> > Where to put in the Digitizer Schemes this line? Is the place in schemes affect the change appear on the map?
> > Thanks in advance for any help or idea where to find the solution.
> > Zsolt GAL
> > Mapbender_users mailing list
> > <Mapbender_users at lists.osgeo.org>
> > <https://lists.osgeo.org/mailman/listinfo/mapbender_users>
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20191111/423f0bad/attachment.html>
More information about the Mapbender_users mailing list
