[Mapbender-users] Please help - refreshLayersAfterFeatureSave -
    Astrid Emde (WhereGroup)
    astrid.emde at wheregroup.com
    Mon Nov 11 00:49:04 PST 2019
Hello Zsolt,
you can't use this parameter with Mapbender 3.0.8.4 and Digitizer
version 1.0.x
You would have to take the newer digitzer version 1.3.
https://github.com/mapbender/mapbender-digitizer/releases/tag/v1.3-beta21
You have to build Mapbender with this version. Please follow the git
based installation.
https://github.com/mapbender/mapbender-starter/blob/master/README.md#getting-the-code
And replace the digitizer version with
/mapbender-starter/application/composer.json file
"mapbender/digitizer": "v1.3-beta21 at dev"
Best regards Astrid
Am 2019-11-11 06:26, schrieb Gal Zsolt:
> Hello List!
> I have a layer MyLines from my Geoserver on the main map. MyLines is a
> table in a PostgresSQL database.
> I edit MyLines with Digitizer, and change the field LineColor.
> The change effect appear only after I pan or zoom on the map.
> I use
> refreshLayersAfterFeatureSave:
>                 - 164
> where 164 is the Instance-ID of my layer.
> Where to put in the Digitizer Schemes this line? Is the place in
> schemes affect the change appear on the map?
> Thanks in advance for any help or idea where to find the solution.
> Zsolt GAL
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Where2B Konferenz 2019
12. Dezember 2019 in Bonn
where2b-conference.com
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Fon: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users
