[Mapbender-users] Fwd: Re: Please help - refreshLayersAfterFeatureSave -
Gal Zsolt
zsolt.gal at satelitnt.com
Tue Nov 12 06:51:32 PST 2019
Finaly work.
First I upgrade Mapbender and Digitizer.
But the digitizer won't work API query error and no lines appear,
until in parameters.yml I change the database_host to localhost. Previously it was the IP address of my server.
Thank you Astrid for your help.
Zsolt
---------- Forwarded message ----------
From: Astrid Emde (WhereGroup) <astrid.emde at wheregroup.com>
Date: 11 November 2019 at 10:49:04 +02:00
Subject: Re: [Mapbender-users] Please help - refreshLayersAfterFeatureSave -
To: zsolt.gal at satelitnt.com, Mapbender User List <mapbender_users at lists.osgeo.org>
Hello Zsolt,
you can't use this parameter with Mapbender 3.0.8.4 and Digitizer version 1.0.x
You would have to take the newer digitzer version 1.3.
<https://github.com/mapbender/mapbender-digitizer/releases/tag/v1.3-beta21>
You have to build Mapbender with this version. Please follow the git based installation.
<https://github.com/mapbender/mapbender-starter/blob/master/README.md#getting-the-code>
And replace the digitizer version with /mapbender-starter/application/composer.json file
"mapbender/digitizer": "v1.3-beta21 at dev"
Best regards Astrid
Am 2019-11-11 06:26, schrieb Gal Zsolt:
> Hello List!
> I have a layer MyLines from my Geoserver on the main map. MyLines is a
> table in a PostgresSQL database.
> I edit MyLines with Digitizer, and change the field LineColor.
> The change effect appear only after I pan or zoom on the map.
> I use
> refreshLayersAfterFeatureSave:
> - 164
> where 164 is the Instance-ID of my layer.
> Where to put in the Digitizer Schemes this line? Is the place in
> schemes affect the change appear on the map?
> Thanks in advance for any help or idea where to find the solution.
> Zsolt GAL
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> <https://lists.osgeo.org/mailman/listinfo/mapbender_users>
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Where2B Konferenz 2019
12. Dezember 2019 in Bonn
where2b-conference.com
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
<http://www.wheregroup.com>
Folgen Sie der WhereGroup auf twitter:
<http://twitter.com/WhereGroup_com>
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20191112/8aab0878/attachment.html>
More information about the Mapbender_users
