[Mapbender-users] Fwd: Re: Please help - refreshLayersAfterFeatureSave -
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Tue Nov 12 08:53:12 PST 2019
Hello Zsolt,
thanks for sharing and great that you had success!
If you find any bug in digitizer 1.3 please let us knwo.
See you Astrid
Am 2019-11-12 15:51, schrieb Gal Zsolt:
> Finaly work.
> First I upgrade Mapbender and Digitizer.
> But the digitizer won't work API query error and no lines appear,
> until in parameters.yml I change the database_host to localhost.
> Previously it was the IP address of my server.
> Thank you Astrid for your help.
> Zsolt
> ---------- Forwarded message ----------
> From: Astrid Emde (WhereGroup) <astrid.emde at wheregroup.com>
> Date: 11 November 2019 at 10:49:04 +02:00
> Subject: Re: [Mapbender-users] Please help -
> To: zsolt.gal at satelitnt.com, Mapbender User List
> <mapbender_users at lists.osgeo.org>
> Hello Zsolt,
> you can't use this parameter with Mapbender 3.0.8.4 and Digitizer
> version 1.0.x
> You would have to take the newer digitzer version 1.3.
> https://github.com/mapbender/mapbender-digitizer/releases/tag/v1.3-beta21
> You have to build Mapbender with this version. Please follow the git
> based installation.
> https://github.com/mapbender/mapbender-starter/blob/master/README.md#getting-the-code
> And replace the digitizer version with
> /mapbender-starter/application/composer.json file
> "mapbender/digitizer": "v1.3-beta21 at dev"
> Best regards Astrid
> Am 2019-11-11 06:26, schrieb Gal Zsolt:
>> Hello List!
>> I have a layer MyLines from my Geoserver on the main map. MyLines is
>> a
>> table in a PostgresSQL database.
>> I edit MyLines with Digitizer, and change the field LineColor.
>> The change effect appear only after I pan or zoom on the map.
>> I use
>> refreshLayersAfterFeatureSave:
>> - 164
>> where 164 is the Instance-ID of my layer.
>> Where to put in the Digitizer Schemes this line? Is the place in
>> schemes affect the change appear on the map?
>> Thanks in advance for any help or idea where to find the solution.
>> Zsolt GAL
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Where2B Konferenz 2019
> 12. Dezember 2019 in Bonn
> where2b-conference.com
> Astrid Emde
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 22
> Fax: +49(0)228 90 90 38 - 11
> www.wheregroup.com [1]
> Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Links:
> [1] http://www.wheregroup.com
Astrid Emde
GIS-Consultant
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   www.wheregroup.com
Geschäftsführer:
More information about the Mapbender_users mailing list
