[Mapbender-users] Problem with WMS from ArcGIS-Server
Charlotte Toma (WhereGroup)
charlotte.toma at wheregroup.com
Thu Oct 17 09:08:17 PDT 2019
Hello Patrick,
you are right.
I tested this wms with version 3.0.8.4 and got the same 'error' and
missing map request. Sometimes arcgis server suggests formats like pdf
as a default value and mapbender can’t work with them. In your wms I can
see, that 'image/bmp' is the default format for GetMap requests, but
(as you told us) with jpeg/png I saw your map in qgis ...
BUT after this error I tested the wms with mapbender in the version
3.0.6 and everything worked fine. Could you add this error as a bug
ticket for mapbender 3.0.8.x in the git repo?
https://mapbender3.org/?q=en/issue-tracker
Sorry - no solution from me :/
Greetings
Charly
Am 17.10.19 um 15:53 schrieb Patrick Meis:
> Hello List,
> I‘m having problems with icorporating several WMS from neighboring
> cities into our Mapbender 3 project.
> All the WMS with problems come from ArcGIS-Server.
> Here is one oft them (from the city of Coesfeld, Germany):
> http://www.kreis-coesfeld.de/arcgis/services/InspireDenkmale/MapServer/WMSServer?
> Also when i try to use the WMS-Loader in the Mapbender demo-Project i
> dont get a positive result.
> https://demo.mapbender.org/application/mapbender_user_yml
> The WMS simply generates only getLegendGraphic-Requests, but no
> getMap-Requests.
> When i try the WMS in ArcGIS or QGIS, it works fine.
> Any ideas?
> Thanks in advance
> Patrick
> Der Schutz Ihrer personenbezogenen Daten ist der Stadt Münster ein
> wichtiges Anliegen. Die Datenschutzerklärung finden Sie unter
> folgendem Link: https://www.stadt-muenster.de/datenschutz.html
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Where2B Konferenz 2019
12. Dezember 2019 in Bonn
where2b-conference.com
Charlotte Toma
GIS-Consultant
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 24
Fax: +49 (0)228 / 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20191017/981eb66f/attachment.html>
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20191017/981eb66f/attachment.key>
More information about the Mapbender_users
