[Mapbender-users] Problem with WMS from ArcGIS-Server
Patrick Meis
Meis at stadt-muenster.de
Thu Oct 17 23:37:21 PDT 2019
Hello Charly,
thanks for testing it in 3.0.6, i fit seems to be working there, then i can actually assume that the error is not on my side.
Could you be so nice and try this WMS too?
http://www.kreis-coesfeld.de/arcgisservices/Bauleitplanung/MapServer/WMSServer?
Again this one works ok in ArcGIS and QGIS but when i load it into Mapbender 3.0.8.3 the getMap-Request looks like this:
https://www.kreis-coesfeld.de/arcgis/services/Bauleitplanung/MapServer/WmsServer?_signature=28%253AfFL358V9ZtTnCB6eoQWX92lMSQI&TRANSPARENT=TRUE&FORMAT=image%252Fpng&VERSION=1.3.0&EXCEPTIONS=application%252Fvnd.ogc.se_xml&SERVICE=WMS&REQUEST=GetMap&STYLES=&LAYERS=1&_OLSALT=0.48922565327507583&CRS=EPSG%253A25832&BBOX=273174.2661018,5704711.0561353,539735.63878625,5834631.7251747&WIDTH=2380&HEIGHT=1160
This generates the following error message:
<ServiceExceptionReport version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd"><ServiceException code="InvalidFormat">
Parameter 'exceptions' contains unacceptable value.
</ServiceException><ServiceException code="InvalidCRS">
Parameter 'srs(crs)' has wrong value.
</ServiceException></ServiceExceptionReport>
There seems to be a problem with the parameter for the CRS, CRS=EPSG&253A25832, when i change it manually to CRS=EPSG&3A25832 it works.
The getMap-Request from Mapbender seems to first escape the colon in EPSG:25832 to %3A, and then wrongly escaping the ampersand a second time to &253a.
I cannot imagine any way of exerting influence over how Mapbender constructs the getMap...
Could this be another bug?
Then i could file the 2 errors in the same bug ticket.
Patrick
Von: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Charlotte Toma (WhereGroup)
Gesendet: Donnerstag, 17. Oktober 2019 18:08
An: mapbender_users at lists.osgeo.org
Betreff: Re: [Mapbender-users] Problem with WMS from ArcGIS-Server
[Vorsicht Internetmail]:
Diese Mail haben Sie über das Internet erhalten. Bitte Anlagen und Links nur öffnen, wenn keine Anhaltspunkte für Viren vorliegen. Weitere Informationen finden Sie auch in der FAQ Outlook<https://intranet-ms.stadt-muenster.de/citeq/kommunikation/outlook/haeufige-fragen/>
Hello Patrick,
you are right.
I tested this wms with version 3.0.8.4 and got the same 'error' and missing map request. Sometimes arcgis server suggests formats like pdf as a default value and mapbender can't work with them. In your wms I can see, that 'image/bmp' is the default format for GetMap requests, but (as you told us) with jpeg/png I saw your map in qgis ...
BUT after this error I tested the wms with mapbender in the version 3.0.6 and everything worked fine. Could you add this error as a bug ticket for mapbender 3.0.8.x in the git repo?
https://mapbender3.org/?q=en/issue-tracker
Sorry - no solution from me :/
Greetings
Charly
Am 17.10.19 um 15:53 schrieb Patrick Meis:
Hello List,
I'm having problems with icorporating several WMS from neighboring cities into our Mapbender 3 project.
All the WMS with problems come from ArcGIS-Server.
Here is one oft them (from the city of Coesfeld, Germany):
http://www.kreis-coesfeld.de/arcgis/services/InspireDenkmale/MapServer/WMSServer?
Also when i try to use the WMS-Loader in the Mapbender demo-Project i dont get a positive result.
https://demo.mapbender.org/application/mapbender_user_yml
The WMS simply generates only getLegendGraphic-Requests, but no getMap-Requests.
When i try the WMS in ArcGIS or QGIS, it works fine.
Any ideas?
Thanks in advance
Patrick
Der Schutz Ihrer personenbezogenen Daten ist der Stadt Münster ein wichtiges Anliegen. Die Datenschutzerklärung finden Sie unter folgendem Link: https://www.stadt-muenster.de/datenschutz.html
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org<mailto:Mapbender_users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapbender_users
Where2B Konferenz 2019
12. Dezember 2019 in Bonn
where2b-conference.com
Charlotte Toma
GIS-Consultant
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 24
Fax: +49 (0)228 / 90 90 38 - 11
info at wheregroup.com<mailto:info at wheregroup.com>
www.wheregroup.com<http://www.wheregroup.com>
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20191018/d4935618/attachment.html>
More information about the Mapbender_users
