[Mapbender-users] No access via Mapbender to PostgreSQL
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Mon Apr 13 23:28:36 PDT 2020
Hello Anna,
did you mean Mapbender version 3.0.8.5?
Looks like in you config.yml the dbsearch connection is not defined.
Please check the file again.
and have a look in the documentation at
https://doc.mapbender.org/en/customization/yaml.html#id2
Please delete your cache and open Mapbender with app_dev.php
Astrid
Am 2020-04-09 22:09, schrieb Marie Anna Baovola:
> Hello everyone,
> I would like to add the digitizer element (and Search) to my webmap
> but still I got an error message like
> "You have requested a non-existent service
> "doctrine.dbal.dbsearch_connection". Did you mean this:
> "doctrine.dbal.default_connection"?" at
> /var/www/mapbender3/app/bootstrap.php.cache line 2255
> {"exception":"[object]
> (Symfony\\Component\\DependencyInjection\\Exception\\ServiceNotFoundException(code:
> 0)".
> I use ubuntu 18.04 - PostgreSQL 10 - Mapbender 3.0.7.5 and php 7.2.
> (php7.2-pgsql with required packages already installed + extension
> pdo_pgsql uncommented in php.ini).
> Even if I change the database to the default one (mapbender3), the
> error message is always appearing and I couldn't have access and write
> to the database.
> Any suggestions, please?
> Thank you and best regards.
> Baovola.
> BAOVOLA Marie Anna
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users
