[Mapbender-users] Different Schema than public
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Thu Apr 23 22:45:07 PDT 2020
Hello Jan,
it is possible and very easy.
When you define the table you only have to add the schema to the table
definition:
f.e table: myschema.mytable
featureType:
connection: search_db
table: myschema.poi
uniqueId: gid
geomType: point
geomField: geom
srid: 4326
https://doc.mapbender.org/en/functions/editing/digitizer.html
Best regards
Astrid
Am 2020-04-23 20:44, schrieb Jan Dombrowski:
> Hello,
> I‘m trying to implement the digitizer in my MapBender application. So
> fare everything works fine, as long as I use PUBLIC in my Postgresql
> DB as source schema.
> But I would like to use a different one as source schema. Is this in
> general possible? And if yes, how to change the dB_search
> configuration then?
> Thanks for every hint
> Regards Jan
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users
