[Mapbender-users] Different Schema than public
Jan Dombrowski
j.dombrowski at gmx.de
Thu Apr 23 23:56:15 PDT 2020
Hello Astrid,
that works perfect. Thank you for your prompt help.
Best regards
Jan
> Am 24.04.2020 um 07:45 schrieb Astrid Emde (WhereGroup) <astrid.emde at wheregroup.com>:
> Hello Jan,
> it is possible and very easy.
> When you define the table you only have to add the schema to the table definition:
> f.e table: myschema.mytable
> featureType:
> connection: search_db
> table: myschema.poi
> uniqueId: gid
> geomType: point
> geomField: geom
> srid: 4326
> https://doc.mapbender.org/en/functions/editing/digitizer.html
> Best regards
> Astrid
> Am 2020-04-23 20:44, schrieb Jan Dombrowski:
>> Hello,
>> I‘m trying to implement the digitizer in my MapBender application. So
>> fare everything works fine, as long as I use PUBLIC in my Postgresql
>> DB as source schema.
>> But I would like to use a different one as source schema. Is this in
>> general possible? And if yes, how to change the dB_search
>> configuration then?
>> Thanks for every hint
>> Regards Jan
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Astrid Emde
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 22
> Fax: +49(0)228 90 90 38 - 11
> www.wheregroup.com
> Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users
