[Mapbender-users] Thematic Layertree YAML
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Tue Jan 7 03:21:56 PST 2020
Hello Philipp,
you are right, the information is missing at the moment. I opened a
ticket for the docuemntation team
https://github.com/mapbender/mapbender-documentation/issues/146
Here is the information how to create the thematic layertree via yaml
definition
Layertree needs the information useTheme: true
Then you can refer to the layersets in secion themes. Refer to  the name
that you defined for the layerset at id:.
You can define the order of the layersets by the order that you refer to
them.
You can define setting for each layerset.
                      layertree:
                          title: mb.core.layertree.class.title
                          class: Mapbender\CoreBundle\Element\Layertree
                          target: map
                          type: element
                          autoOpen: false
                          showBaseSource: true
                          layerRemove: true
                          menu: [opacity,zoomtolayer,metadata]
                          useTheme: true
                          themes:
                                  title: MainMap
                                  useTheme: true
                                  sourceVisibility: true
                                  allSelected: true
                                  opened: false
                                  title: OpenStreetMap
                                  useTheme: true
                                  allSelected: true
                                  opened: false
Hope this helps.
Best regards
Astrid
Am 2019-11-28 07:44, schrieb Wermuth, Philipp:
> Hello List,
> I'm trying to set up a Thematic Layertree in an Application YAML.
> Unfortunately I didn't find anything in the documentation.
> I hope someone here can help me.
> We currently use the Mapbender version 3.0.7.7
> Mit freundlichen Grüßen
> Technische Betriebe Velbert AöR
> i.A.
> Philipp Wermuth
> Sachgebiet 3.2 - Geodaten
> Am Lindenkamp 33
> 42549 Velbert
> Raum 2.56
> Tel.: 02051/26-2650
> Fax: 02051/26-132650
> e-Mail: philipp.wermuth at velbert.de
> Internet: www.tbv-velbert.de [1]
> Informationen der TBV zum Datenschutz [2]
> Links:
> [1] http://troubadix.wheregroup.com/www.tbv-velbert.de
> [2] https://www.tbv-velbert.de/datenschutzerklaerung/
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Astrid Emde
GIS-Consultant
  Aufwind durch Wissen!
  Qualifizierte Open-Source-Schulungen
  bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Fon: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users mailing list
