[Mapbender-users] Search Rout
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Thu Jan 16 23:48:14 PST 2020
Hello Siline,
please add a text column that contains your line_ref_num and search with
this column instead with line_ref_num.
Mapbender can only handle text. So maybe this will help.
Astrid
Am 2020-01-17 08:34, schrieb Siline:
> Hello,
> I found error, but I still can't fix the error. please help.
> This is error:
> An exception occurred while executing 'SELECT t.`line_id`,
> t.`line_ref_num`,
> t.`chainage`, t.`line_name`, ST_AsGeoJSON(ST_Transform(t.`line_wkt`,
> ?::int)) as geom FROM gis_line_t1 t WHERE (t.line_ref_num LIKE ?) AND
> (ST_Transform(ST_SetSRID(ST_MakeBox2D(ST_Point(?, ?), ST_Point(?, ?)),
> ST_Srid(t.`line_wkt`)) && t.`line_wkt`)' with params [32648,
> "%0806T1001%",
> 5579.905, 1088581.723, 1029359.857, 1650396.77, 32648]:
> SQLSTATE[42000]: Syntax error or access violation: 1064 You have an
> error in
> your SQL syntax; check the manual that corresponds to your MariaDB
> server
> version for the right syntax to use near '::int)) as geom FROM
> gis_line_t1 t
> WHERE (t.line_ref_num LIKE '%0806T1001%' at line 1
> Best,
> Siline
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/mapbender-users-f4220788.html
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users
