Hello Thomsen, Thank you for pointing in the right direction. I have an issue with bad credentials and I found the answer here by following the URL you've provided. Now I am able to log in. Thanks -- Sent from: http://osgeo-org.1560.x6.nabble.com/mapbender-users-f4220788.html
