[Mapbender-users] Installing Geomoose
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Thu Jan 30 00:02:29 PST 2020
Hello Lara,
looks like you are on the wrong list. This is the Mapbender list :)
Mapbender is another WebGIS Client Suite that is also great!
Check out the GeoMoose Mailing List
https://www.geomoose.org/info/mailing_lists.html
Best regards Astrid
Am 2020-01-30 08:42, schrieb LARA:
> Hi everyone. First, say that Geomoose developers have done a great
> job. Select this software after trying Geoserver, Openlayers,
> QgisServer, etc ... largely due to its ability to represent different
> types of information (SHP, ECW ... etc) and especially because the
> user query environment It seems intuitive, simple, clear and with
> great features. I have installed the software and I am including my
> own information by customizing the sample demo data. I encounter the
> problem of the initial display. I use UTM ETRS89 N. I have changed the
> map extension in the mapbook.xml, in the app.js and in the * .map ...
> and nothing ... the initial visualization is still wrong ... that I am
> missing ? Thank you...
> app.js:
> app.loadMapbook({url: 'mapbook.xml'}).then(function() { // set the
> default view. app.setView({ center: [ 746000 , 4304950 ], zoom: 2 });
> app.registerAction('fullextent', ZoomToAction, { extent:
> [746000,4304950,758122,4314545] });
> geomoose.glabals.map:
> PROJECTION "init=epsg:25830" END EXTENT 746000 4304950 758100 4314500
> Winodws Server 2016. MS4W 2019-12-19. Apache 2.4. Mapserver 5.6.
> Geomoose 3.4.0. Thanks in advance
> [1]
> CAP DEL DEPARTAMENT DE CARTOGRAFIA I TOPOGRAFIA
> Lara Perez Bessone
> Enginyera Tecnica Topografa Municipal
> email: topografia at oliva.es Tel. mòvil: 647 835 086 ext. 521
> AJUNTAMENT D'OLIVA - VALÈNCIA
> Plaça del Ajuntament 1, 46780 Oliva
> Tel. 962850250 Fax 962855165 www.oliva.es [2]
> Links:
> [1] http://oliva.es/es/
> [2] http://www.oliva.es
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users
