[Mapbender-users] MapBender print error
karsten
karsten at terragis.net
Wed Jul 1 00:50:44 PDT 2020
sorry the line was cut off complete it is
[2020-07-01 09:02:09] request.CRITICAL: Uncaught PHP Exception
Symfony\Component\Routing\Exception\ResourceNotFoundException: "" at
/var/www/mapbender3/app/cache/prod/appProdProjectContainerUrlMatcher.php
line 1122 {"exception":"[object]
(Symfony\\Component\\Routing\\Exception\\ResourceNotFoundException(code: 0):
at
/var/www/mapbender3/app/cache/prod/appProdProjectContainerUrlMatcher.php:112
2)"} []
_____
From: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] On
Behalf Of karsten
Sent: Wednesday, July 01, 2020 00:45
To: 'Mapbender User List'
Subject: Re: [Mapbender-users] MapBender print error
I found the following in the MapBender log file:
[2020-07-01 09:31:46] app.DEBUG: Print Request Nr.: 0
http://theserverorl.com/cgi-bin/mapserv?map=/var/www/mapdata/xyz.map$
[2020-07-01 09:31:46] request.CRITICAL: Uncaught PHP Exception
/var/www/mapbender3/app/c$
[2020-07-01 09:31:46] security.DEBUG: Stored the security token in the
session. {"key":"_security_secured_area"} []
_____
Sent: Wednesday, July 01, 2020 00:42
Subject: MapBender print error
Hi all,
I have a MapBender v 3.0.6.3 installation on Ubuntu 16 and overall
everything is working fine.
In an older application the print client is working correctly on that same
server however in a new MapBender application when trying to print I get an
"500 Internal Server Error"( call to
http://theserverorl.com/application/mapbender_new2020/element/320/print ) .
I also created a new print template (in am attempt to fix this)
in which I deleted all but the "map" element in the *.odg template file but
to no avail. Any ideas what could be wrong and how to fix this ?
Cheers
Karsten
Karsten Vennemann
Terra GIS LTD
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20200701/0e207794/attachment.html>
More information about the Mapbender_users
