[Mapbender-users] "app/console mapbender:config:check" is ok, but no login page!
Denis Ju
de.ju.mail.01 at gmail.com
Tue Jul 7 09:12:15 PDT 2020
hi all,
it seems everything ok with "app/console mapbender:config:check", but no
login page!
Any idea what's is going wrong?
Check Database connections
Connection Status Message
mapbender successfull ok
Check PHP Version
Your Version Required Version Message
7.2.24-0ubuntu0.18.04.6 5.5.4 ok
Check System Requirements
Extension name Is loaded? Message
sqlite3 yes ok
curl yes ok
gd yes ok
intl yes ok
mbstring yes ok
fileinfo yes ok
openssl yes ok
bz2 yes ok
zip yes ok
xml yes ok
Check Asset Folders
Folder is Symlink?
fomcore yes
fomuser yes
framework yes
mapbendercoordinatesutility yes
mapbendercore yes
mapbenderdatasource yes
mapbenderdigitizer yes
mapbendermanager yes
mapbendermobile yes
mapbenderprint yes
mapbenderwmc yes
mapbenderwms yes
Check FastCGI
proxy_fcgi (enabled by unknown)
fcgid (enabled by maintainer script)
Check Apache mod_rewrite
rewrite (enabled by unknown)
Check PHP ini
Parameter Value
date.timezeone
max_input_vars 1000
MaxRequestLen
max_execution_time 0
memory_limit -1
upload_max_filesize 2M
oci8.max_persistent
oci8.default_prefetch
session.save_handler files
zend_extension
opcache.enable 1
opcache.memory_consumption 128
opcache.interned_strings_buffer 8
opcache.max_accelerated_files 10000
opcache.max_wasted_percentage 5
Loaded PHP Extensions
* Core
* date
* libxml
* openssl
* pcre
* zlib
* filter
* hash
* pcntl
* Reflection
* SPL
* sodium
* session
* standard
* mysqlnd
* PDO
* xml
* apcu
* apc
* bz2
* calendar
* ctype
* curl
* dom
* mbstring
* fileinfo
* ftp
* gd
* gettext
* iconv
* intl
* json
* exif
* mysqli
* pdo_mysql
* pdo_pgsql
* pdo_sqlite
* pgsql
* Phar
* posix
* readline
* shmop
* SimpleXML
* sockets
* sqlite3
* sysvmsg
* sysvsem
* sysvshm
* tokenizer
* wddx
* xmlreader
* xmlwriter
* xsl
* zip
* Zend OPcache
Check Permissions
Folder User Group Permissions
app/logs/ ubuntuuser ubuntuuser 0775
app/cache/ ubuntuuser ubuntuuser 0775
web/uploads/ ubuntuuser ubuntuuser 0775
web/xmlschemas/ ubuntuuser ubuntuuser 0775
web/ ubuntuuser ubuntuuser 0775
Regards
Denis
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20200707/f3716280/attachment-0001.html>
More information about the Mapbender_users
