[Mapbender-users] "app/console mapbender:config:check" is ok, but no login page!
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Tue Jul 7 23:26:23 PDT 2020
Hello Denis,
did you create an Apache Alias that refers to Mapbender?
https://doc.mapbender.org/en/installation/installation_ubuntu.html#configuration-apache-2-4
Maybe that is the pronblem.
Astrid
Am 2020-07-07 18:12, schrieb Denis Ju:
> hi all,
> it seems everything ok with "app/console mapbender:config:check", but
> no login page!
> Any idea what's is going wrong?
> Check Database connections
> Connection Status Message
> mapbender successfull ok
> Check PHP Version
> Your Version Required Version Message
> 7.2.24-0ubuntu0.18.04.6 5.5.4 ok
> Check System Requirements
> Extension name Is loaded? Message
> sqlite3 yes ok
> curl yes ok
> gd yes ok
> intl yes ok
> mbstring yes ok
> fileinfo yes ok
> openssl yes ok
> bz2 yes ok
> zip yes ok
> xml yes ok
> Check Asset Folders
> Folder is Symlink?
> fomcore yes
> fomuser yes
> framework yes
> mapbendercoordinatesutility yes
> mapbendercore yes
> mapbenderdatasource yes
> mapbenderdigitizer yes
> mapbendermanager yes
> mapbendermobile yes
> mapbenderprint yes
> mapbenderwmc yes
> mapbenderwms yes
> Check FastCGI
> proxy_fcgi (enabled by unknown)
> fcgid (enabled by maintainer script)
> Check Apache mod_rewrite
> rewrite (enabled by unknown)
> Check PHP ini
> Parameter Value
> date.timezeone
> max_input_vars 1000
> MaxRequestLen
> max_execution_time 0
> memory_limit -1
> upload_max_filesize 2M
> oci8.max_persistent
> oci8.default_prefetch
> session.save_handler files
> zend_extension
> opcache.enable 1
> opcache.memory_consumption 128
> opcache.interned_strings_buffer 8
> opcache.max_accelerated_files 10000
> opcache.max_wasted_percentage 5
> Loaded PHP Extensions
> * Core
> * date
> * libxml
> * openssl
> * pcre
> * zlib
> * filter
> * hash
> * pcntl
> * Reflection
> * SPL
> * sodium
> * session
> * standard
> * mysqlnd
> * PDO
> * xml
> * apcu
> * apc
> * bz2
> * calendar
> * ctype
> * curl
> * dom
> * mbstring
> * fileinfo
> * ftp
> * gd
> * gettext
> * iconv
> * intl
> * json
> * exif
> * mysqli
> * pdo_mysql
> * pdo_pgsql
> * pdo_sqlite
> * pgsql
> * Phar
> * posix
> * readline
> * shmop
> * SimpleXML
> * sockets
> * sqlite3
> * sysvmsg
> * sysvsem
> * sysvshm
> * tokenizer
> * wddx
> * xmlreader
> * xmlwriter
> * xsl
> * zip
> * Zend OPcache
> Check Permissions
> Folder User Group Permissions
> app/logs/ ubuntuuser ubuntuuser 0775
> app/cache/ ubuntuuser ubuntuuser 0775
> web/uploads/ ubuntuuser ubuntuuser 0775
> web/xmlschemas/ ubuntuuser ubuntuuser 0775
> web/ ubuntuuser ubuntuuser 0775
> Regards
> Denis
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Jetzt neu: Webinare und Online-Schulungen
bei der www.foss-academy.com
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users
