[Mapbender-users] Frameworks Analysis / Mapbender Functionalities
Lilia Pleskach
pleslillia at gmail.com
Mon Jun 1 08:38:03 PDT 2020
Dear all,
As a part of my university project, I have to analyse the functionalities
of some geospatial frameworks (GeoMoose, GeoNode, Mapbender, geOrchestra,
MapMint and LizMap). I made this analysis using the official user
documentation of each framework, but sometimes there were some
confusing information or lack of information.
If you have two minutes of your time, could you please check and comment if
there is wrong information or if it is not complete?
There is the link to Google Sheets with comments access (right click of the
mouse to leave the comment):
https://docs.google.com/spreadsheets/d/1bJEEoHlRZBZTW6Da8YpT_ZCqxnfyk6nswO7lrXQuW8U/edit?usp=sharing
On the bottom you can see six sheets of each framework. I decided to give
access to all the tables if one day you need to use/check the
information about another framework. I'll also update all the tables at the
end of my project, so you can see the actual information.
Thank you !
Regards,
Lilia
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20200601/9eb33512/attachment.html>
More information about the Mapbender_users
