[Mapbender-users] Frameworks Analysis / Mapbender Functionalities
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Mon Jun 1 23:24:15 PDT 2020
Hello Lilia,
thanks a lot for reaching out to the Mapbender project and great to hear
about your university project.
I added some comments to your sheet. Hope they help.
It would be great if you could send a link to you results when your
analysis is ready.
Astrid
Am 2020-06-01 17:38, schrieb Lilia Pleskach:
> Dear all,
> As a part of my university project, I have to analyse the
> functionalities of some geospatial frameworks (GeoMoose, GeoNode,
> Mapbender, geOrchestra, MapMint and LizMap). I made this analysis
> using the official user documentation of each framework, but sometimes
> there were some confusing information or lack of information.
> If you have two minutes of your time, could you please check and
> comment if there is wrong information or if it is not complete?
> There is the link to Google Sheets with comments access (right click
> of the mouse to leave the comment):
> https://docs.google.com/spreadsheets/d/1bJEEoHlRZBZTW6Da8YpT_ZCqxnfyk6nswO7lrXQuW8U/edit?usp=sharing
> On the bottom you can see six sheets of each framework. I decided to
> give access to all the tables if one day you need to use/check the
> information about another framework. I'll also update all the tables
> at the end of my project, so you can see the actual information.
> Thank you !
> Regards,
> Lilia
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
  Aufwind durch Wissen!
  Jetzt neu: Webinare und Online-Schulungen
  bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Fon: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users mailing list
