[Mapbender-users] Popup window with terms and conditions
Gal Zsolt
zsolt.gal at satelitnt.com
Mon Jun 15 13:04:58 PDT 2020
Thanks, Charly. I try (OK work) and I will use your tip.
It's not 100% the solution I need. The user can close the dialog:
* clicking right top corner (close)
* clicking outside the copyrighjt dialog box
For the second case, I find the solution: in mapbender.element.copyright.jsI modify closeOnOutsideClick: true, to closeOnOutsideClick:false,
For the first case I need to Google for a solution.
Thanks again,
Zsolt
On 15 June 2020 at 11:00:20 +03:00, Toma, Charlotte <Charlotte.Toma at wiesbaden.de> wrote:
> Hi Zsolt,
> you can use the „copyright“ element:
> <https://doc.mapbender.org/en/functions/misc/copyright.html>
> Add the element „copyright“ in the content of your application and write your (html)-text with the terms and conditions. Furthermore you need to enable the checkbox „auotopen“.
> Greetings
> Charly
> Mit freundlichen Grüßen
> im AuftragCharlotte Toma
> Landeshauptstadt Wiesbaden
> Stadtplanungsamt
> Von:Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag vonGal Zsolt
> Gesendet: Dienstag, 9. Juni 2020 19:24
> An: Mapbender_users at lists.osgeo.org
> Betreff: [Mapbender-users] Popup window with terms and conditions
> Hello list, Mapbender User,
> I make a public application (no user name and password requiered).
> I wan't a popup window where the user accept that the maps have informative contents and can't use it as a legal document! If accept the application can be accessed by user.
> I will thank any advice or solution.
> Thanks, Zsolt.
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20200615/9e2e11ff/attachment.html>
More information about the Mapbender_users
