[Mapbender-users] WMS error
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Mon Oct 19 00:04:47 PDT 2020
Am 2020-10-14 20:42, schrieb Jeff McKenna:
> On 2020-10-14 3:09 p.m., BRIAN STIFFENN LUNA BOLIVAR wrote:
>> Hello everyone, good day, greetings from Colombia. I am doing my
>> graduate work, for which I am implementing a geovisor through
>> Mapbender.
>> I am adding the WMS service
>> (http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/DATA/geoserviciosgeiper.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities)
>> However the platform (through the application Mapbender Demo Map)
>> throws the following error: "The map can not be displayed" Everything
>> it's well configured in the WMS, because I proved in other platforms
>> like: QGIS, ArcGIS.
>> Please. Can you help me?
>> Q: I'm using the Mapbender 3.0.8.5 on MS4W version.
> By the way, for MS4W using the home IP is recommended
> (http://127.0.0.1/cgi-bin/mapserv.exe?map=..) as over the many years
> (now decades) managing this for MS4W users I have seen problems with
> "localhost", so, if you want my advice, be sure to always use
> 127.0.0.1 in your local testing.
> Thanks again and hello from the east coast of Canada,
> -jeff
Hello Brian,
greetings to Colombia from Cologne :)
If you have still problems please try:
1. Set MAXSIZE to 6000 in your mapfile. Mapbender will always request a
bigger map. The default of MapServer is 4096 from MapServer > 7.0.3
https://www.mapserver.org/mapfile/map.html
2. Debug Mapbender with F12
Go to the Network tab and find the map request ther. Open the map
request in a new tab. -> Is there an error?
3. Does your application support the EPSG code of your WMS
Hope that helps.
Best Astrid
Astrid Emde
GIS-Consultant
  Aufwind durch Wissen!
  Jetzt neu: Web-Seminare und Online-Schulungen
  bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Fon: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users mailing list
