[Mapbender-users] WMS error
BRIAN STIFFENN LUNA BOLIVAR
bslunab at correo.udistrital.edu.co
Wed Oct 14 12:52:46 PDT 2020
The QGIS plugin, works perfectly fine, it doesn't show any trouble with the
getmap request.
El mié., 14 oct. 2020 a las 14:51, BRIAN STIFFENN LUNA BOLIVAR (<
bslunab at correo.udistrital.edu.co>) escribió:
> Thank you Jeff, I appreciate your response. I'm using the QGIS plugin but
> still have the same problem. So I tried with the mapcache WMS request (
> http://127.0.0.1/mapcache/wms?SERVICE=WMS&Request=GetCapabilities) but
> the problem persists.
> Let me show the following image, it runs only with the Mapbender Users wms
> request.
> [image: imagen.png]
> El mié., 14 oct. 2020 a las 13:42, Jeff McKenna (<
> jmckenna at gatewaygeomatics.com>) escribió:
>> On 2020-10-14 3:09 p.m., BRIAN STIFFENN LUNA BOLIVAR wrote:
>> > Hello everyone, good day, greetings from Colombia. I am doing my
>> > graduate work, for which I am implementing a geovisor through Mapbender.
>> > I am adding the WMS service
>> http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/DATA/geoserviciosgeiper.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities)
>> > However the platform (through the application Mapbender Demo Map)
>> throws
>> > the following error: "The map can not be displayed" Everything it's
>> well
>> > configured in the WMS, because I proved in other platforms like: QGIS,
>> > ArcGIS.
>> > Please. Can you help me?
>> > Q: I'm using the Mapbender 3.0.8.5 on MS4W version.
>> By the way, for MS4W using the home IP is recommended
>> (http://127.0.0.1/cgi-bin/mapserv.exe?map=..) as over the many years
>> (now decades) managing this for MS4W users I have seen problems with
>> "localhost", so, if you want my advice, be sure to always use 127.0.0.1
>> in your local testing.
>> Thanks again and hello from the east coast of Canada,
>> -jeff
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> co-founder of FOSS4G
>> http://gatewaygeo.com/
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20201014/00e7b8fd/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20201014/00e7b8fd/attachment-0001.png>
More information about the Mapbender_users
