[Mapbender-users] WMS error
BRIAN STIFFENN LUNA BOLIVAR bslunab at correo.udistrital.edu.co
Wed Oct 14 12:51:18 PDT 2020
Thank you Jeff, I appreciate your response. I'm using the QGIS plugin but
still have the same problem. So I tried with the mapcache WMS request (
http://127.0.0.1/mapcache/wms?SERVICE=WMS&Request=GetCapabilities) but the
problem persists.
Let me show the following image, it runs only with the Mapbender Users wms
request.
[image: imagen.png]
El mié., 14 oct. 2020 a las 13:42, Jeff McKenna (<
jmckenna at gatewaygeomatics.com>) escribió:
> On 2020-10-14 3:09 p.m., BRIAN STIFFENN LUNA BOLIVAR wrote:
> > Hello everyone, good day, greetings from Colombia. I am doing my
> > graduate work, for which I am implementing a geovisor through Mapbender.
> > I am adding the WMS service
> http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/DATA/geoserviciosgeiper.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities)
> > However the platform (through the application Mapbender Demo Map) throws
> > the following error: "The map can not be displayed" Everything it's well
> > configured in the WMS, because I proved in other platforms like: QGIS,
> > ArcGIS.
> > Please. Can you help me?
> > Q: I'm using the Mapbender 3.0.8.5 on MS4W version.
> By the way, for MS4W using the home IP is recommended
> (http://127.0.0.1/cgi-bin/mapserv.exe?map=..) as over the many years
> (now decades) managing this for MS4W users I have seen problems with
> "localhost", so, if you want my advice, be sure to always use 127.0.0.1
> in your local testing.
> Thanks again and hello from the east coast of Canada,
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> co-founder of FOSS4G
> http://gatewaygeo.com/
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20201014/991ef18d/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20201014/991ef18d/attachment-0001.png>
More information about the Mapbender_users mailing list
