[Mapbender-users] weird mapbender visualisation of layer tree on some clients
Michael Tiede m.tiede at eberswalde.de
Wed Sep 23 05:19:30 PDT 2020
Dear mapbender friends,
we have a server with mapbender v3.0.8.1. running. With this instance
we are running 2 mapprojects.
For some reason the folder icons (open/expanded and closed folder icon)
and checkboxes of the layertree in the sidepane are not displayed on
some clients for one of both map projects. The other map project. is
shown correctly. on same client.. So it is not possible to realize which
layer is turned on or off. Tried with firefox, chrome, edge and ie. All
browsers are showing same weird layertree visualisation for one of both
mapprojects.
Trying to call the mapserverproject with weird visualisation on
anothter client at same time is fine.
Thoughts of Windows Updates as the cause were rejected as one
mapproject is shown correctly. The problem appears on several clients
and also some month after last editings on the project. The layertree
was shown correctly two weeks ago on said client.
Any clues are appreciated.
WICHTIGER HINWEIS
Als Anhänge werden nur die Dateiformate pdf, docx und xlsx problemlos
zugestellt. Aus Sicherheitsgründen können Office-Dateiformate, die
ausführbare Programmcodes enthalten könnten (insbesondere doc, dot,
rtf und xls), nicht akzeptiert werden. Andere Formate werden erst nach
erfolgter Sicherheitsüberprüfung zugestellt, was mit Zeitverzögerung
verbunden ist.
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20200923/f5beb013/attachment-0001.png>
More information about the Mapbender_users mailing list
