[Mapbender-users] weird mapbender visualisation of layer tree on some clients
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Wed Sep 23 05:59:08 PDT 2020
Hello,
looks like a styling-problem.
- have you tried a deep refresh with ctrl-F5?
- can you delete the browser-cache?
- are all symbols / fonts and css loaded properly (you can check it with
F12 looking at the network-tab)
Jörg Thomsen
Am 23.09.20 um 14:19 schrieb Michael Tiede:
> Dear mapbender friends,
> we have a server with mapbender v3.0.8.1. running. With this instance
> we are running 2 mapprojects.
> For some reason the folder icons (open/expanded and closed folder icon)
> and checkboxes of the layertree in the sidepane are not displayed on
> some clients for one of both map projects. The other map project. is
> shown correctly. on same client.. So it is not possible to realize which
> layer is turned on or off. Tried with firefox, chrome, edge and ie. All
> browsers are showing same weird layertree visualisation for one of both
> mapprojects.
> Trying to call the mapserverproject with weird visualisation on
> anothter client at same time is fine.
> Thoughts of Windows Updates as the cause were rejected as one
> mapproject is shown correctly. The problem appears on several clients
> and also some month after last editings on the project. The layertree
> was shown correctly two weeks ago on said client.
> Any clues are appreciated.
> WICHTIGER HINWEIS
> Als Anhänge werden nur die Dateiformate pdf, docx und xlsx problemlos
> zugestellt. Aus Sicherheitsgründen können Office-Dateiformate, die
> ausführbare Programmcodes enthalten könnten (insbesondere doc, dot,
> rtf und xls), nicht akzeptiert werden. Andere Formate werden erst nach
> erfolgter Sicherheitsüberprüfung zugestellt, was mit Zeitverzögerung
> verbunden ist.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Viele Grüße,
Jörg Thomsen
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Fon: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the Mapbender_users
