[Mapbender-users] weird mapbender visualisation of layer tree on some clients
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Wed Sep 23 06:46:35 PDT 2020
Hello,
please update your Mapbender to 3.0.8.6.
This problem should  be solved in this version
https://mapbender.org/builds/3.0.8.6/
It occured when you open Mapbender with different links f.e
http://localhost/mapbender/
http://localhost/mapbender/app.php
Then the images are displayed fine with one link but not with the other.
If you do not want to update:
* delete the mapbender cache under mapbender/app/cache
* make sure that your users use only one of the two ways to open the
application.
Best regards
Astrid Emde
Am 2020-09-23 14:59, schrieb Jörg Thomsen:
> Hello,
> looks like a styling-problem.
> - have you tried a deep refresh with ctrl-F5?
> - can you delete the browser-cache?
> - are all symbols / fonts and css loaded properly (you can check it
> with
> F12 looking at the network-tab)
> Jörg Thomsen
> Am 23.09.20 um 14:19 schrieb Michael Tiede:
>> Dear mapbender friends,
>> we have a server with mapbender v3.0.8.1. running. With this instance
>> we are running 2 mapprojects.
>> For some reason the folder icons (open/expanded and closed folder
>> icon)
>> and checkboxes of the layertree in the sidepane are not displayed on
>> some clients for one of both map projects. The other map project. is
>> shown correctly. on same client.. So it is not possible to realize
>> which
>> layer is turned on or off. Tried with firefox, chrome, edge and ie.
>> All
>> browsers are showing same weird layertree visualisation for one of
>> both
>> mapprojects.
>> Trying to call the mapserverproject with weird visualisation on
>> anothter client at same time is fine.
>> Thoughts of Windows Updates as the cause were rejected as one
>> mapproject is shown correctly. The problem appears on several clients
>> and also some month after last editings on the project. The layertree
>> was shown correctly two weeks ago on said client.
>> Any clues are appreciated.
>> WICHTIGER HINWEIS
>> Als Anhänge werden nur die Dateiformate pdf, docx und xlsx problemlos
>> zugestellt. Aus Sicherheitsgründen können Office-Dateiformate, die
>> ausführbare Programmcodes enthalten könnten (insbesondere doc, dot,
>> rtf und xls), nicht akzeptiert werden. Andere Formate werden erst nach
>> erfolgter Sicherheitsüberprüfung zugestellt, was mit Zeitverzögerung
>> verbunden ist.
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Viele Grüße,
> Jörg Thomsen
> Aufwind durch Wissen!
> Jetzt neu: Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com
> Jörg Thomsen
> WhereGroup GmbH
> Bundesallee 23
> 10717 Berlin
> Germany
> Fon: +49 (0)30 / 5130 278 74
> Fax: +49 (0)30 / 5130 278 11
> joerg.thomsen at wheregroup.com
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Fon: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
Geschäftsführer:
More information about the Mapbender_users mailing list
