[Mapbender-users] weird mapbender visualisation of layer tree on some clients
Michael Tiede
m.tiede at eberswalde.de
Thu Sep 24 02:14:32 PDT 2020
Dear Astrid,
deleting the mapbender cache under mapbender/app/cache but also the
browser cache solved the problem.
Thanks a lot
Hello,
please update your Mapbender to 3.0.8.6.
This problem should be solved in this version
https://mapbender.org/builds/3.0.8.6/
It occured when you open Mapbender with different links f.e
http://localhost/mapbender/
http://localhost/mapbender/app.php
Then the images are displayed fine with one link but not with the
other.
If you do not want to update:
* delete the mapbender cache under mapbender/app/cache
* make sure that your users use only one of the two ways to open the
application.
Best regards
Astrid Emde
Am 2020-09-23 14:59, schrieb Jörg Thomsen:
> Hello,
> looks like a styling-problem.
> - have you tried a deep refresh with ctrl-F5?
> - can you delete the browser-cache?
> - are all symbols / fonts and css loaded properly (you can check it
> with
> F12 looking at the network-tab)
> Jörg Thomsen
> Am 23.09.20 um 14:19 schrieb Michael Tiede:
>> Dear mapbender friends,
>> we have a server with mapbender v3.0.8.1. running. With this
instance
>> we are running 2 mapprojects.
>> For some reason the folder icons (open/expanded and closed folder
>> icon)
>> and checkboxes of the layertree in the sidepane are not displayed
on
>> some clients for one of both map projects. The other map project.
is
>> shown correctly. on same client.. So it is not possible to realize
>> which
>> layer is turned on or off. Tried with firefox, chrome, edge and ie.
>> All
>> browsers are showing same weird layertree visualisation for one of
>> both
>> mapprojects.
>> Trying to call the mapserverproject with weird visualisation on
>> anothter client at same time is fine.
>> Thoughts of Windows Updates as the cause were rejected as one
>> mapproject is shown correctly. The problem appears on several
clients
>> and also some month after last editings on the project. The
layertree
>> was shown correctly two weeks ago on said client.
>> Any clues are appreciated.
>> WICHTIGER HINWEIS
>> Als Anhänge werden nur die Dateiformate pdf, docx und xlsx
problemlos
>> zugestellt. Aus Sicherheitsgründen können Office-Dateiformate, die
>> ausführbare Programmcodes enthalten könnten (insbesondere doc, dot,
>> rtf und xls), nicht akzeptiert werden. Andere Formate werden erst
nach
>> erfolgter Sicherheitsüberprüfung zugestellt, was mit
Zeitverzögerung
>> verbunden ist.
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Viele Grüße,
> Jörg Thomsen
> Aufwind durch Wissen!
> Jetzt neu: Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com
> Jörg Thomsen
> WhereGroup GmbH
> Bundesallee 23
> 10717 Berlin
> Germany
> Fon: +49 (0)30 / 5130 278 74
> Fax: +49 (0)30 / 5130 278 11
> joerg.thomsen at wheregroup.com
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
astrid.emde at wheregroup.com
www.wheregroup.com
Geschäftsführer:
WICHTIGER HINWEIS
Als Anhänge werden nur die Dateiformate pdf, docx und xlsx problemlos
rtf und xls), nicht akzeptiert werden. Andere Formate werden erst nach
erfolgter Sicherheitsüberprüfung zugestellt, was mit Zeitverzögerung
verbunden ist.
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20200924/3a62b070/attachment.html>
More information about the Mapbender_users
