[Mapbender-users] Mapbender, GetFeatureInfo with user style?
Göldner, Reiner Dr. - LfA Reiner.Goeldner at lfa.sachsen.de
Fri Sep 25 04:59:26 PDT 2020
Hello,
unfortunately I use ArcGIS Server and didn't find a possibility to configure the style for a single layer yet. For the whole service it does work but is explicitly not recommended. May be the ESRI service desk can help me.
You mentioned to add the XLST info to the GetFeaturInfo request. Could it be done by configuration or is it necessary to modify software?
Best Regards,
Reiner
-----Ursprüngliche Nachricht-----
Von: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Astrid Emde (WhereGroup)
Gesendet: Freitag, 25. September 2020 12:34
An: Mapbender User List <mapbender_users at lists.osgeo.org>
Betreff: Re: [Mapbender-users] Mapbender, GetFeatureInfo with user style?
Hello,
with text/html you can integrate images and links.
Which MapServer Software do you use?
With GeoServer, MapServer. QGIS Server this is possible. You have to check the documentation there.
If you want to use &xsl_template=ownURL/userstyle.xsl You have to add this information to your featureinfo Request. This is also possible. But the solutions from  GeoServer, MapServer. QGIS Server are easier to handle.
Astrid
Am 2020-09-25 12:08, schrieb Göldner:
> Hello,
> within an application layer I can choose the Infoformat (e.g.
> text/html). Is there a possibility to change from these standard
> formats of GetFeatureInfo to a user defined style? That would be
> useful to design special attributes appearing as an image or as a
> download link.
> As I now, GetFeatureInfo allows a parameter like
> „…&xsl_template=ownURL/userstyle.xsl“, where userstyle.xls is a
> modified XSLT document.
> Or is there another possibility to popup an image or a download link
> by clicking on the map and taking the URL from a feature attribute?
> Best Regards
> Reiner
> Dr. Reiner Göldner
> Referent GIS
> ______________________________________________________________________
> __
> LANDESAMT FÜR ARCHÄOLOGIE SACHSEN│SAXON ARCHAEOLOGICAL HERITAGE OFFICE
> Zur Wetterwarte 7 │01109 Dresden
> Tel: +49 351 8926 803│Fax: +49 351 8926 999
> reiner.goeldner at lfa.sachsen.de │ www.archaeologie.sachsen.de [1] Kein
> Zugang für elektronisch signierte sowie für verschlüsselte
> elektronische Dokumente
> Links:
> [1] http://www.archaeologie.sachsen.de/
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
  Aufwind durch Wissen!
  Jetzt neu: Web-Seminare und Online-Schulungen
  bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Fon: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   astrid.emde at wheregroup.com
   www.wheregroup.com
   Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users mailing list
