[Mapbender-users] Mapbender, GetFeatureInfo with user style?
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Sun Sep 27 23:29:01 PDT 2020
Hello,
you could add the XLST to the getFeatureInfo-request
1. Go To the table mb_wms_wmssource and add the reference to the xslt to
the link
like
XSL_template=http://myserver/arcgis/rest/directories/arcgisoutput/featureinfo_text_xx.xsl
Then the information should always be added for this WMS to the
getFeatureInfo Request.
or
2. you also could add the information as vendor specific in the WMS
instance
https://doc.mapbender.org/de/quickstart.html#konfiguration-von-diensten
Best regards
Astrid
Am 2020-09-25 13:59, schrieb Göldner:
> Hello,
> unfortunately I use ArcGIS Server and didn't find a possibility to
> configure the style for a single layer yet. For the whole service it
> does work but is explicitly not recommended. May be the ESRI service
> desk can help me.
> You mentioned to add the XLST info to the GetFeaturInfo request. Could
> it be done by configuration or is it necessary to modify software?
> Best Regards,
> Reiner
> -----Ursprüngliche Nachricht-----
> Von: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org]
> Im Auftrag von Astrid Emde (WhereGroup)
> Gesendet: Freitag, 25. September 2020 12:34
> An: Mapbender User List <mapbender_users at lists.osgeo.org>
> Betreff: Re: [Mapbender-users] Mapbender, GetFeatureInfo with user
> style?
> Hello,
> with text/html you can integrate images and links.
> Which MapServer Software do you use?
> With GeoServer, MapServer. QGIS Server this is possible. You have to
> check the documentation there.
> If you want to use &xsl_template=ownURL/userstyle.xsl You have to add
> this information to your featureinfo Request. This is also possible.
> But the solutions from  GeoServer, MapServer. QGIS Server are easier
> to handle.
> Astrid
> Am 2020-09-25 12:08, schrieb Göldner:
>> Hello,
>> within an application layer I can choose the Infoformat (e.g.
>> text/html). Is there a possibility to change from these standard
>> formats of GetFeatureInfo to a user defined style? That would be
>> useful to design special attributes appearing as an image or as a
>> download link.
>> As I now, GetFeatureInfo allows a parameter like
>> „…&xsl_template=ownURL/userstyle.xsl“, where userstyle.xls is a
>> modified XSLT document.
>> Or is there another possibility to popup an image or a download link
>> by clicking on the map and taking the URL from a feature attribute?
>> Best Regards
>> Reiner
>> Dr. Reiner Göldner
>> Referent GIS
>> ______________________________________________________________________
>> __
>> LANDESAMT FÜR ARCHÄOLOGIE SACHSEN│SAXON ARCHAEOLOGICAL HERITAGE OFFICE
>> Zur Wetterwarte 7 │01109 Dresden
>> Tel: +49 351 8926 803│Fax: +49 351 8926 999
>> reiner.goeldner at lfa.sachsen.de │ www.archaeologie.sachsen.de [1] Kein
>> Zugang für elektronisch signierte sowie für verschlüsselte
>> elektronische Dokumente
>> Links:
>> [1] http://www.archaeologie.sachsen.de/
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
>   Aufwind durch Wissen!
>   Jetzt neu: Web-Seminare und Online-Schulungen
>   bei der www.foss-academy.com
>    Astrid Emde
>    WhereGroup GmbH
>    Eifelstraße 7
>    53119 Bonn
>    Germany
>    Fon: +49(0)228 90 90 38 - 22
>    Fax: +49(0)228 90 90 38 - 11
>    www.wheregroup.com
>    Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
Astrid Emde
GIS-Consultant
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   www.wheregroup.com
Geschäftsführer:
More information about the Mapbender_users mailing list
