[Mapbender-users] LDAP integration
Adrián Ariza
hardian at gmail.com
Fri Apr 23 20:17:25 PDT 2021
Sorry, The mapbender I'm using is 3.2.3
El vie, 23 abr 2021 a las 23:19, Adrián Ariza (<hardian at gmail.com>)
escribió:
> I try but the message still seid that the problem is in
> /vendor/mapbender/ldapbundle/DependencyInjection/../Resources/config/services.yml"
> line 13 near "- @ldapClient").
> I delete the @ and now I'm getting
> Uncaught PHP Exception
> Symfony\Component\Debug\Exception\FatalThrowableError: "Type error:
> Argument 1 passed to
> Mapbender\LDAPBundle\Security\Provider\LDAPUserProvider::__construct() must
> implement interface Symfony\Component\Ldap\LdapClientInterface, string
> given, called in
> /var/www/puntogis3/app/cache/dev/ContainerEbn4jh3/getLdapUserProviderService.php
> on line 8" at
> /var/www/puntogis3/vendor/mapbender/ldapbundle/Security/Provider/LDAPUserProvider.php
> line 48
> Any Clues? Anyone are using ldap? The mapbender/ldapbundle works with
> 3.0.4 version?
> Thanks in advance!
> El vie, 23 abr 2021 a las 4:12, Philipp van Biesbrock (<
> philipp.vanbiesbrock at wheregroup.com>) escribió:
>> looks like you need to wrap an entry in parameters.yml in single quotes:
>> Something like this, I guess:
>> ldap.user.dn: 'user at example.com'
>> Am 23.04.21 um 01:22 schrieb Adrián Ariza:
>> Thanks for your reply!
>> I Install ldapBundle, configure security and parameters but now I see the
>> error
>> The reserved indicator "@" cannot start a plain scalar; you need to quote
>> the scalar at line 13 (near "- @ldapClient").
>> Could you gime som clue about fixing that?
>> Thanks in advance!
>> PD: Sorry for my english
>> El jue, 22 abr 2021 a las 6:03, Philipp van Biesbrock (<
>>> Hi Adrián,
>>> Unfortunately we currently don't have any documentation. We're working
>>> on it though.
>>> Here's a quick tutorial for you:
>>> To use Mapbender with LDAP you can add this Symfony-bundle to your
>>> Mapbender:
>>> https://github.com/mapbender/ldapBundle
>>> This can be done manually or via composer: composer require
>>> Don't forget to register in AppKernel.php
>>> Configuration isn't too easy. Basically you need to configure
>>> security.yml and parameters.yml.
>>> Security.yml needs the ldapProvider and some firewall configuration:
>>> providers:
>>> ldapProvider:
>>> main:
>>> entity:
>>> class: FOM\UserBundle\Entity\User
>>> property: username
>>> chain_provider:
>>> chain:
>>> providers: ["ldapProvider","main"]
>>> firewalls:
>>> secured_area:
>>> pattern: ^/
>>> anonymous: ~
>>> provider: chain_provider
>>> mapbender_ldap:
>>> login_path: /user/login
>>> check_path: /user/login/check
>>> service: ldapClient
>>> form_login:
>>> provider: main
>>> logout:
>>> path: /user/logout
>>> target: /
>>> Add this to parameters.yml fitting your ldap server configuration:
>>> ldap.host: example.com
>>> ldap.port: 389
>>> ldap.version: 3
>>> ldap.useTLS: false
>>> ldap.useSSL: false
>>> ldap.bind.dn: cn=admin,dc=example,dc=com
>>> ldap.bind.pwd: *********
>>> ldap.user.nameAttribute: cn
>>> ldap.user.baseDn: ou=user,dc=example,dc=com
>>> ldap.user.adminFilter: (objectClass=*)
>>> ldap.user.query: (&(cn={username})(objectclass=top))
>>> ldap.user.dn: cn={username},ou=user,dc=example,dc=com
>>> ldap.user.password: unicodePwd={password}
>>> ldap.group.nameAttribute:~
>>> ldap.group.baseDn: ou=groups,dc=example,dc=com
>>> ldap.group.adminFilter: (objectClass=*)
>>> ldap.group.id: cn
>>> ldap.group.query: member=cn={username},ou=user,dc=example,dc=com
>>> Now this probably won't work right away. Depending on your Ldap server
>>> settings it can be quite a hassle to get this running.
>>> Hope this helps.
>>> Am 22.04.21 um 06:12 schrieb Adrián Ariza:
>>> Hi! Are there any tutorial to configure LDA FOM? How to activate,
>>> configure and debug.
>>> Thanks in advance!
>>> Mapbender_users mailing listMapbender_users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/mapbender_users
>>> Mit freundlichen Grüßen
>>> Aufwind durch Wissen!
>>> Web-Seminare und Online-Schulungen
>>> bei der www.foss-academy.com
>>> WhereGroup GmbH
>>> Eifelstraße 7
>>> 53119 Bonn
>>> Germany
>>> Fon: +49 (0)228 / 90 90 38 - **
>>> Fax: +49 (0)228 / 90 90 38 - 11
>>> info at wheregroup.comwww.wheregroup.com
>>> Geschäftsführer:
>>> Olaf Knopp, Peter Stamm
>>> Amtsgericht Bonn, HRB 9885
>> WhereGroup GmbH
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Geschäftsführer:
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20210424/457a7735/attachment-0001.html>
More information about the Mapbender_users
