[Mapbender-users] Print size A1
Gal Zsolt zsolt.gal at satelitnt.com
Mon Feb 8 05:05:43 PST 2021
Hi Reiner!
Thank you for detailed explanation. Now I print A0 and is ok.
Danke.
Zsolt
On February 8, 2021 at 11:18:04 am +02:00, Göldner, Reiner Dr. - LfA <Reiner.Goeldner at lfa.sachsen.de> wrote:
> Hi Zsolt,
> this may result from the maximum resolution of the used WMS-Service, that often is 2000*2000 or 4000*4000 pixel. You find it in the capabilities of the service. With this, the measure of your print area and the print resolution you can find out, if it will work or not. For me a resolution of 100 dpi at 4000*4000 works, e.g.
> Best regards
> Reiner
> Dr. Reiner GöldnerReferent GIS
> ________________________________________________________________________LANDESAMT FÜR ARCHÄOLOGIE SACHSEN│SAXON ARCHAEOLOGICAL HERITAGE OFFICEZur Wetterwarte 7│01109 DresdenTel: +49 351 8926 803│Fax: +49 351 8926 999<reiner.goeldner at lfa.sachsen.de>│<http://www.archaeologie.sachsen.de/>Kein Zugang für elektronisch signierte sowie für verschlüsselte elektronische Dokumente
> Von:Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag vonGal Zsolt
> Gesendet: Sonntag, 7. Februar 2021 21:36
> An: Mapbender User List <mapbender_users at lists.osgeo.org>
> Betreff: [Mapbender-users] Print size A1
> Hello list!
> Someone make A1 size print from Mapbender?
> I try and I succeeded but only at 150 dp resolution. Above this resolution the PDF file is created but the map is empty.
> I change in php.ini the memory_limit to 1G, 4G, or -1 without any result, map is empty.
> I thanks in advance for any help to solve this.
> Zsolt
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20210208/91aa7a5d/attachment-0001.html>
More information about the Mapbender_users mailing list
