[Mapbender-users] Print size A1
    Göldner, Reiner Dr. - LfA
    Reiner.Goeldner at lfa.sachsen.de
    Mon Feb  8 01:18:04 PST 2021
Hi Zsolt,
this may result from the maximum resolution of the used WMS-Service, that often is 2000*2000 or 4000*4000 pixel. You find it in the capabilities of the service. With this, the measure of your print area and the print resolution you can find out, if it will work or not. For me a resolution of  100 dpi at 4000*4000 works, e.g.
Best regards
Reiner
Dr. Reiner Göldner
Referent GIS
________________________________________________________________________
LANDESAMT FÜR ARCHÄOLOGIE SACHSEN│SAXON ARCHAEOLOGICAL HERITAGE OFFICE
Zur Wetterwarte 7 │01109 Dresden
Tel: +49 351 8926 803│Fax: +49 351 8926 999
reiner.goeldner at lfa.sachsen.de<mailto:reiner.goeldner at lfa.sachsen.de> │ www.archaeologie.sachsen.de<http://www.archaeologie.sachsen.de/>
Kein Zugang für elektronisch signierte sowie für verschlüsselte elektronische Dokumente
Von: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Gal Zsolt
Gesendet: Sonntag, 7. Februar 2021 21:36
An: Mapbender User List <mapbender_users at lists.osgeo.org>
Betreff: [Mapbender-users] Print size A1
Hello list!
Someone make A1 size print from Mapbender?
I try and I succeeded but only at 150 dp resolution. Above this resolution the PDF file is created but the map is empty.
I change  in php.ini  the  memory_limit to 1G, 4G, or -1 without any result, map is empty.
I thanks in advance for any help to solve this.
Zsolt
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20210208/dfe45928/attachment.html>
More information about the Mapbender_users
