[Mapbender-users] Print size A1
Gal Zsolt
zsolt.gal at satelitnt.com
Sun Feb 7 12:35:30 PST 2021
Hello list!
Someone make A1 size print from Mapbender?
I try and I succeeded but only at 150 dp resolution. Above this resolution the PDF file is created but the map is empty.
I change in php.ini the memory_limit to 1G, 4G, or -1 without any result, map is empty.
I thanks in advance for any help to solve this.
Zsolt
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20210207/f3a08943/attachment.html>
More information about the Mapbender_users
