[Mapbender-users] Mapbender installation PHP configuration
Walter White Jr. whitejrdot at gmail.com
Sun Jan 3 13:24:00 PST 2021
Hi folks,
I want to install Mapbender 3.0.8 on Windows 10 to launch an own web-gis
app on my website but have some problems with the PHP installation. I
already have installed PHP 7.2.33, Apache 2.4 and PostgreSQL 9 but have
some problems with the PHP configuration.
(1) It needs to be checked if the following variables (php.ini) are set
correctly:
sys_temp_dir
upload_tmp_dir
date.timezone
Where should I check this? In the cmd, one of the php.exe files?
(2)   “the path from PHP-bin directory to the PATH-variable (Windows
environment variable) needs to be set”
There is no PHP-bin directory in the PHP file after installation so how can
I add the PHP-bin path as another Win environment var?
(3)   “activate the required PHP extensions in the php.ini configuration
file:”
# php.ini
extension=php_curl.dll
extension=php_fileinfo.dll
extension=php_gd2.dll
extension=php_intl.dll
extension=php_pdo_pgsql.dll
extension=php_pdo_sqlite.dll
extension=php_pgsql.dll
extension=php_openssl.dll
extension=php_mbstring.dll
extension=php_zip.dll
extension=php_bz2.dll
Should I just add these lines into the php.ini file or what should I do?
I want to emphasize I am not a web developer so I suppose these are
elementary questions but since Mapbender promises to create map apps
without a single line of code I was hoping I can manage that on my own
(have some knowledge about GDI). I was not able to find something helpful
on the internet so I hope you can help me with this. Would appreciate any
help.
Many thanks in advance!
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
Virenfrei.
www.avast.com
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20210103/a9368da4/attachment.html>
More information about the Mapbender_users mailing list
