[Mapbender-users] Cannot change application security permissions after mapbender update
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Wed Jun 16 23:07:09 PDT 2021
Hello Joel,
I can not reproduce the error. Everything works fine at my installation.
Did you try the app_dev.php mode too?
What is your php version?
Astrid
Am 2021-06-14 22:08, schrieb Joel Blizzard:
> In upgrading from Mapbender 3.2.3 to 3.2.5 I no longer have the
> ability to adjust security settings on the applications I've created.
> So if I go into an application, and go to the "Security" tab, if I try
> to remove public access, or add a user to the list, or make any kind
> of change to existing permissions for an application, when I click
> Save, I get an internal 500 error.
> When I look at my logs on the server, I see this error:
> [php7:notice] [pid 4589] [client <IPaddress>:63695] PHP Notice:
> Undefined offset: 2 in
> /var/www/mapbender/vendor/symfony/security-acl/Dbal/MutableAclProvider.php
> on line 981
> That is referring to this section of MutableAclProvider.php:
> Line 981 is the one that says "$ace = $old[$i]"
> private function updateOldFieldAceProperty($name, array $changes)
> $currentIds = array();
> foreach ($changes[1] as $field => $new) {
> for ($i = 0, $c = count($new); $i < $c; ++$i) {
> $ace = $new[$i];
> if (null !== $ace->getId()) {
> $currentIds[$ace->getId()] = true;
> foreach ($changes[0] as $old) {
> for ($i = 0, $c = count($old); $i < $c; ++$i) {
> $ace = $old[$i];
> if (!isset($currentIds[$ace->getId()])) {
> $this->connection->executeQuery($this->getDeleteAccessControlEntrySql($ace->getId()));
> unset($this->loadedAces[$ace->getId()]);
> Can anyone assist me in figuring out what's gone wrong here?
> Thank you!
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufbau von Geodateninfrastrukturen mit Open-Source-Software
FOSS Academy 5 Tage-Kompaktkurs „Sommerschule 2021"
Jetzt anmelden: https://foss-academy.com/kompaktkurse/
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20210617/620167b5/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20210617/620167b5/attachment.sig>
More information about the Mapbender_users
