[Mapbender-users] Cannot change application security permissions after mapbender update
Joel Blizzard
jrpblizz at gmail.com
Thu Jun 17 14:38:00 PDT 2021
Did you try doing an install and then an upgrade?
php version is PHP 7.2.24-0ubuntu0.18.04.7
Unfortunately I cannot run dev mode, as this is running on a cloud hosted
server that I do not have a GUI on. Is there a way to run it from a system
other than localhost?
I looked in the documentation and it says " Symfony offers a developer mode
with lot of information about your application (logging, exceptions,
database queries, memory usage, time and more). This mode is only available
from localhost."
On Thu, Jun 17, 2021 at 1:07 AM Astrid Emde (WhereGroup) <
astrid.emde at wheregroup.com> wrote:
> Hello Joel,
> I can not reproduce the error. Everything works fine at my installation.
> Did you try the app_dev.php mode too?
> What is your php version?
> Astrid
> Am 2021-06-14 22:08, schrieb Joel Blizzard:
> > In upgrading from Mapbender 3.2.3 to 3.2.5 I no longer have the
> > ability to adjust security settings on the applications I've created.
> > So if I go into an application, and go to the "Security" tab, if I try
> > to remove public access, or add a user to the list, or make any kind
> > of change to existing permissions for an application, when I click
> > Save, I get an internal 500 error.
> > When I look at my logs on the server, I see this error:
> > [php7:notice] [pid 4589] [client <IPaddress>:63695] PHP Notice:
> > Undefined offset: 2 in
> /var/www/mapbender/vendor/symfony/security-acl/Dbal/MutableAclProvider.php
> > on line 981
> > That is referring to this section of MutableAclProvider.php:
> > Line 981 is the one that says "$ace = $old[$i]"
> > private function updateOldFieldAceProperty($name, array $changes)
> > $currentIds = array();
> > foreach ($changes[1] as $field => $new) {
> > for ($i = 0, $c = count($new); $i < $c; ++$i) {
> > $ace = $new[$i];
> > if (null !== $ace->getId()) {
> > $currentIds[$ace->getId()] = true;
> > foreach ($changes[0] as $old) {
> > for ($i = 0, $c = count($old); $i < $c; ++$i) {
> > $ace = $old[$i];
> > if (!isset($currentIds[$ace->getId()])) {
> $this->connection->executeQuery($this->getDeleteAccessControlEntrySql($ace->getId()));
> > unset($this->loadedAces[$ace->getId()]);
> > Can anyone assist me in figuring out what's gone wrong here?
> > Thank you!
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Aufbau von Geodateninfrastrukturen mit Open-Source-Software
> FOSS Academy 5 Tage-Kompaktkurs „Sommerschule 2021"
> Jetzt anmelden: https://foss-academy.com/kompaktkurse/
> Astrid Emde
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 22
> Fax: +49(0)228 90 90 38 - 11
> www.wheregroup.com
> Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> -------------------------------_______________________________________________
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20210617/edd3281c/attachment.html>
More information about the Mapbender_users
