[Mapbender-users] Digitizer popup buttons V3.3
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Mon Apr 25 07:52:05 PDT 2022
Hello Gal,
this is not possible anymore.
The documentation is out of date and needs an update
https://doc.mapbender.org/en/functions/editing/digitizer/digitizer_configuration.html#buttons
But you can modify the code to add your button:
Add a copy of the file mapbender.element.digitizer.js from
vendor/mapbender/digitizer/Resources/public/mapbender.element.digitizer.js
to
mapbender/application/app/Resources/MapbenderDigitizerBundle/public/mapbender.element.digitizer.js
and add to the function _getEditDialogButtons somthing like
if (schema.useMessageToEditor) {
var body = encodeURI("Sehr geehrter Herr/Frau
xx,\nLink:"+location.href);
buttons.push({
text: 'message to editor',
click: function() {
location.href =
"mailto:firstname.lastname at mail.com?subject=New edit in
webgis&body="+body;
In your digitizer configuration you have to add the parameter in this
case
useMessageToEditor: true
so it would look like
poi:
label: '1 point digitizing'
maxResults: 500
featureType:
connection: geodata_db
table: poi
uniqueId: gid
geomType: point
geomField: geom
srid: 4326
allowEditData: true
allowDelete: true
allowDigitize: true
printable: true
allowChangeVisibility: true
allowCustomStyle: true
refreshFeaturesAfterSave: true
refreshLayersAfterFeatureSave: true
inlineSearch: true
pageLength: 5
<---- new parameter to aadd the button
See you Astrid
Am 2022-04-25 06:29, schrieb Gal Zsolt:
> Hello List!
> In Mapbender 3.3 I can't add button to digitizer form.
> popup:
> title: polygon test suite
> width: 500p
> _# resizible: true_
> buttons:
> - text: message to editor
> click: |
> xx,"+"\nLink:"+location.href);
> location.href =
> webgis&body=Mail to editor for further edits.";
> - text: message to controller
> click: |
> location.href =
> "mailto:firstname.lastname at mail.com&subject=webgis&body=really?";
> It's a bug or this option removed from version 3.3?
> GÁL Zsolt
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Tel: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220425/3243eeb9/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220425/3243eeb9/attachment.sig>
More information about the Mapbender_users
