[Mapbender-users] Logfile / errorfile  from VMS loader
    Astrid Emde (WhereGroup)
    astrid.emde at wheregroup.com
    Thu Mar 17 06:03:28 PDT 2022
Great! Problem solved :)
So hopefully everything is fine now.
Another friend is app_dev.php which gives you additional information.
http://localhost/mapbender/app_dev.php
See you Astrid
Am 2022-03-17 13:36, schrieb Henrik Bytoft Holm:
> F12 is our friend..
> Problem solved.... mixed ssl/non-ssl, if I run everything non-SSL it
> works 😊
> Med venlig hilsen / Best regards
> Henrik Bytoft Holm
> IT-medarbejder
> snapindvej 21 - 5200 Odense v - Denmark
> T: +45 2446 9732
> M: +45 2446 9732
> @: hbh at odenserenovation.dk
> -----Oprindelig meddelelse-----
> Fra: Mapbender_users <mapbender_users-bounces at lists.osgeo.org> På
> vegne af Astrid Emde (WhereGroup)
> Sendt: 17. marts 2022 13:35
> Til: Mapbender User List <mapbender_users at lists.osgeo.org>
> Emne: Re: [Mapbender-users] Logfile / errorfile from VMS loader
> Hello Henrik,
> please check via F12 and look for the Netzwork tab and the errors of
> the WMS map-request.
> Does your WMS support the EPSG of the application?
> F12 is your friend ;)
> See you Astrid
> Am 2022-03-17 13:12, schrieb Henrik Bytoft Holm:
>> Hi,
>> I have installed the mapbender package for windows. I can create ned
>> applications and create baselayers with maps from OSM.
>> I'm trying to load VMS laysers published from out internal
> GeoServer.
>> I can make the connection and see the published layers from the
>> geoserver in the layersets in Mapbender.
>> Then I load the application, my VMS layers is "grey'ed out" (out of
>> box boundary) then I pan/zoom the map into the area where the VMS
>> layer is, the layer becomes red and an error occurs…. The problem
> is
>> there is no error message/tooltip explaining the error…..
>> Where can I see debug information on these errors ?
>> Henrik Bytoft Holm
>> _IT-medarbejder_
>> T:
>>  +45 2446 9732
>> M:
>> +45 2446 9732
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users [1]
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Aufwind durch Wissen!
> Jetzt neu: Web-Seminare und Online-Schulungen bei der
> www.foss-academy.com [2]
>    Astrid Emde
>    WhereGroup GmbH
>    Eifelstraße 7
>    53119 Bonn
>    Germany
>    Tel: +49(0)228 90 90 38 - 22
>    Fax: +49(0)228 90 90 38 - 11
>    www.wheregroup.com [3]
>    Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
> [4]
>    Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>    Folgen Sie der WhereGroup auf twitter:
>    http://twitter.com/WhereGroup_com [5]
>    Geschäftsführer:
>    Olaf Knopp, Peter Stamm
>    Amtsgericht Bonn, HRB 9885
> Links:
> [1] https://lists.osgeo.org/mailman/listinfo/mapbender_users
> [2] http://www.foss-academy.com
> [3] http://www.wheregroup.com
> [4]
> [5] http://twitter.com/WhereGroup_com
Astrid Emde
GIS-Consultant
bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   www.wheregroup.com
   Geschäftsführer:
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220317/86b72092/attachment-0001.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220317/86b72092/attachment-0001.sig>
More information about the Mapbender_users
