[Mapbender-users] Server Error WMS
ihara.olivera at imm.gub.uy
Thu Mar 31 08:42:52 PDT 2022
Thanks for the quick response,
keep in touch xxx.
----- Mensaje original -----
De: "Jörg Thomsen (WhereGroup)" <joerg.thomsen at wheregroup.com>
Para: "Mapbender users" <mapbender_users at lists.osgeo.org>
Enviados: Jueves, 31 de Marzo 2022 12:01:17
Asunto: Re: [Mapbender-users] Server Error WMS
Hello Belen,
looks more like a miss-configuration of the WMS.
getMap:
https://geoserver.montevideo.gub.uy/geoserver/ows?SERVICE=WMS&_signature=34%3AU4eAyyKZ-J0-25u51BfmOl2L0Hw&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image%2Fpng&TRANSPARENT=true&LAYERS=depaseo%3Atours&STYLES=&_OLSALT=0.6642019119728901&CRS=EPSG%3A25832&WIDTH=1688&HEIGHT=1191&BBOX=359697.1662468514%2C5617500%2C372452.8337531486%2C5626500
results to:
<ServiceExceptionReport xmlns="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.3.0"
xsi:schemaLocation="http://www.opengis.net/ogc
http://geoserver.montevideo.gub.uy/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd">
<ServiceException> The requested Style can not be used with this layer.
The style specifies an attribute of horarios and the layer is:
depaseo:tours </ServiceException>
</ServiceExceptionReport>
Jörg
Am 31.03.22 um 16:39 schrieb ihara.olivera at imm.gub.uy:
> To whom it may concern, i'm writing to you in order to solve a problem i
> am recently having with mapbender.
> When i try to load a WMS serivce the application throws an internal
> server error and no layer is shown.
> Here's the WMS
> url:http://geoserver.montevideo.gub.uy/geoserver/ows?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
> <http://geoserver.montevideo.gub.uy/geoserver/ows?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>
> And here's the error i'am having:
> /I look forward to/ hearing /your reply/ asap,
> best wishes,
> Belen.
> El presente correo electrónico y cualquier posible archivo adjunto esta
> dirigido únicamente al destinatario del mismo y contiene información que
> puede ser confidencial. Si Ud. no es el destinatario correcto por favor
> notifique al remitente respondiendo este mensaje y elimine
> inmediatamente de su sistema, el correo electrónico y los posibles
> archivos adjuntos al mismo. Esta prohibida cualquier utilización,
> difusión o copia de este correo electrónico por cualquier persona o
> entidad que no sean las especificas destinatarias del mensaje. La
> Intendencia de Montevideo no acepta ninguna responsabilidad con respecto
> a cualquier comunicación que haya sido emitida incumpliendo nuestra
> normativa municipal, así como lo previsto en la Ley 18.331 de Protección
> de Datos Personales y la Ley 18.381 de Acceso a la Información Publica.
> This e-mail and any attachment is confidential and is intended solely
> for the addressee(s). If you are not intended recipient please inform
> the sender immediately, answering this e-mail and delete it as well as
> the attached files. Any use, circulation or copy of this e-mail by any
> person or entity that is not the specific addressee(s) is prohibited.
> The City Council of Montevideo is not responsible for any communication
> emitted without respecting our Organization Policy or the Data
> Protection Act and Habeas Data Action No. 18.331 and the Information
> Access Act N 18.381.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Viele Grüße,
Jörg Thomsen
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Tel: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
El presente correo electronico y cualquier posible archivo adjunto esta dirigido unicamente al destinatario del mismo y contiene informacion que puede ser confidencial. Si Ud. no es el destinatario correcto por favor notifique al remitente respondiendo este mensaje y elimine inmediatamente de su sistema, el correo electronico y los posibles archivos adjuntos al mismo. Esta prohibida cualquier utilizacion, difusion o copia de este correo electronico por cualquier persona o entidad que no sean las especificas destinatarias del mensaje. La Intendencia de Montevideo no acepta ninguna responsabilidad con respecto a cualquier comunicacion que haya sido emitida incumpliendo nuestra normativa municipal, asi como lo previsto en la Ley 18.331 de Proteccion de Datos Personales y la Ley 18.381 de Acceso a la Informacion Publica.
This e-mail and any attachment is confidential and is intended solely for the addressee(s). If you are not intended recipient please inform the sender immediately, answering this e-mail and delete it as well as the attached files. Any use, circulation or copy of this e-mail by any person or entity that is not the specific addressee(s) is prohibited. The City Council of Montevideo is not responsible for any communication emitted without respecting our Organization Policy or the Data Protection Act and Habeas Data Action No. 18.331 and the Information Access Act N 18.381.
More information about the Mapbender_users
