[Mapbender-users] Server Error WMS
ihara.olivera at imm.gub.uy ihara.olivera at imm.gub.uy
Thu Mar 31 10:13:37 PDT 2022
i'm working on windows with Apache 2.4 and php 7.4.13. I download the app from here https://ms4w.com/ maybe i try with the repository.
Thank's for helping me and sorry if i bother you with this.
----- Mensaje original -----
De: "Armin Retterath" <armin.retterath at vermkv.rlp.de>
Para: "Mapbender users" <mapbender_users at lists.osgeo.org>
Enviados: Jueves, 31 de Marzo 2022 13:52:01
Asunto: Re: [Mapbender-users] Server Error WMS
do you really have an old mapbender 28 installation? ;-)
which os do you use? - we are actually under debian 11 with php 7.4 and postgresql 13
we work with mapbender28 and migrate 2 years ago it to github: https://github.com/mrmap-community/Mapbender2.8/
if you have any further questions, don't hesitate to ask ;-)
best regards from germany
armin
> ihara.olivera at imm.gub.uy hat am 31. März 2022 18:47 geschrieben:
> I already do this,change the variables and restart Apache but still not working (i have mapbender 2.8 version)
> De: "ihara.olivera" <ihara.olivera at imm.gub.uy>
> Para: "astrid emde" <astrid.emde at wheregroup.com>, "Mapbender users" <mapbender_users at lists.osgeo.org>
> Enviados: Jueves, 31 de Marzo 2022 13:38:30
> Hi, how can i restart Apache?
> De: "Astrid Emde (WhereGroup)" <astrid.emde at wheregroup.com>
> Enviados: Jueves, 31 de Marzo 2022 12:50:37
> Hello,
> the service is from Montevideo Uruguay and has many layers
> http://geoserver.montevideo.gub.uy/geoserver/ows?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
> Many layers are possible but you can not visualisize all layers at once
> as the WMS getMap-request has a limited length.
> You can load the WMS to the Mapbender service repository.
> But to configure the service you have to update the php.ini of your
> Mapbender server, as the service has so many layer that the predifined
> configuration for php is at its limit.
> See
> https://doc.mapbender.org/en/faq.html
> Increase the following variables and restart Apache
> max_input_vars = 4000
> memory_limit = 1024M
> But then you also have to limit the active layers for this WMS, as with
> all layers active you will hit the limit for the url-lenth.
> Hope that infromation helps
> Astrid
> Am 2022-03-31 17:01, schrieb Jörg Thomsen:
> > Hello Belen,
> > looks more like a miss-configuration of the WMS.
> > getMap:
> > https://geoserver.montevideo.gub.uy/geoserver/ows?SERVICE=WMS&_signature=34%3AU4eAyyKZ-J0-25u51BfmOl2L0Hw&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image%2Fpng&TRANSPARENT=true&LAYERS=depaseo%3Atours&STYLES=&_OLSALT=0.6642019119728901&CRS=EPSG%3A25832&WIDTH=1688&HEIGHT=1191&BBOX=359697.1662468514%2C5617500%2C372452.8337531486%2C5626500
> > results to:
> > <ServiceExceptionReport xmlns="http://www.opengis.net/ogc"
> > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.3.0"
> > xsi:schemaLocation="http://www.opengis.net/ogc
> > http://geoserver.montevideo.gub.uy/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd">
> > <ServiceException> The requested Style can not be used with this
> > layer. The style specifies an attribute of horarios and the layer is:
> > depaseo:tours </ServiceException>
> > </ServiceExceptionReport>
> > Jörg
> > Am 31.03.22 um 16:39 schrieb ihara.olivera at imm.gub.uy:
> >> To whom it may concern, i'm writing to you in order to solve a problem
> >> i am recently having with mapbender.
> >> When i try to load a WMS serivce the application throws an internal
> >> server error and no layer is shown.
> >> Here's the WMS
> >> url:http://geoserver.montevideo.gub.uy/geoserver/ows?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
> >> <http://geoserver.montevideo.gub.uy/geoserver/ows?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>
> >> And here's the error i'am having:
> >> /I look forward to/ hearing /your reply/ asap,
> >> best wishes,
> >> Belen.
> >> El presente correo electrónico y cualquier posible archivo adjunto
> >> esta dirigido únicamente al destinatario del mismo y contiene
> >> información que puede ser confidencial. Si Ud. no es el destinatario
> >> correcto por favor notifique al remitente respondiendo este mensaje y
> >> elimine inmediatamente de su sistema, el correo electrónico y los
> >> posibles archivos adjuntos al mismo. Esta prohibida cualquier
> >> utilización, difusión o copia de este correo electrónico por cualquier
> >> persona o entidad que no sean las especificas destinatarias del
> >> mensaje. La Intendencia de Montevideo no acepta ninguna
> >> responsabilidad con respecto a cualquier comunicación que haya sido
> >> emitida incumpliendo nuestra normativa municipal, así como lo previsto
> >> en la Ley 18.331 de Protección de Datos Personales y la Ley 18.381 de
> >> Acceso a la Información Publica.
> >> This e-mail and any attachment is confidential and is intended solely
> >> for the addressee(s). If you are not intended recipient please inform
> >> the sender immediately, answering this e-mail and delete it as well as
> >> the attached files. Any use, circulation or copy of this e-mail by any
> >> person or entity that is not the specific addressee(s) is prohibited.
> >> The City Council of Montevideo is not responsible for any
> >> communication emitted without respecting our Organization Policy or
> >> the Data Protection Act and Habeas Data Action No. 18.331 and the
> >> Information Access Act N 18.381.
> >> _______________________________________________
> >> Mapbender_users mailing list
> >> Mapbender_users at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> > Viele Grüße,
> > Jörg Thomsen
> > Aufwind durch Wissen!
> > Jetzt neu: Web-Seminare und Online-Schulungen
> > bei der www.foss-academy.com
> > Jörg Thomsen
> > WhereGroup GmbH
> > Bundesallee 23
> > 10717 Berlin
> > Germany
> > Tel: +49 (0)30 / 5130 278 74
> > Fax: +49 (0)30 / 5130 278 11
> > joerg.thomsen at wheregroup.com
> > www.wheregroup.com
> > Geschäftsführer:
> > Olaf Knopp, Peter Stamm
> > Amtsgericht Bonn, HRB 9885
> > Folgen Sie der WhereGroup auf twitter:
> > http://twitter.com/WhereGroup_com
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
>    Astrid Emde
>    WhereGroup GmbH
>    Eifelstraße 7
>    53119 Bonn
>    Germany
>    Tel: +49(0)228 90 90 38 - 22
>    Fax: +49(0)228 90 90 38 - 11
>    www.wheregroup.com
>    Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
>    Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>    Geschäftsführer:
> El presente correo electronico y cualquier posible archivo adjunto esta dirigido unicamente al destinatario del mismo y contiene informacion que puede ser confidencial. Si Ud. no es el destinatario correcto por favor notifique al remitente respondiendo este mensaje y elimine inmediatamente de su sistema, el correo electronico y los posibles archivos adjuntos al mismo. Esta prohibida cualquier utilizacion, difusion o copia de este correo electronico por cualquier persona o entidad que no sean las especificas destinatarias del mensaje. La Intendencia de Montevideo no acepta ninguna responsabilidad con respecto a cualquier comunicacion que haya sido emitida incumpliendo nuestra normativa municipal, asi como lo previsto en la Ley 18.331 de Proteccion de Datos Personales y la Ley 18.381 de Acceso a la Informacion Publica.
> This e-mail and any attachment is confidential and is intended solely for the addressee(s). If you are not intended recipient please inform the sender immediately, answering this e-mail and delete it as well as the attached files. Any use, circulation or copy of this e-mail by any person or entity that is not the specific addressee(s) is prohibited. The City Council of Montevideo is not responsible for any communication emitted without respecting our Organization Policy or the Data Protection Act and Habeas Data Action No. 18.331 and the Information Access Act N 18.381.
Im Auftrag
Armin Retterath
Zentrale Stelle GDI-RP
LVermGeo Rheinland-Pfalz
Von-Kuhl-Straße 49
56070 Koblenz
Telefon 0261 492-466
Telefax 0261 492-492
http://www.geoportal.rlp.de
More information about the Mapbender_users mailing list
