[Mapbender-users] Server Error WMS
Armin Retterath armin.retterath at gmail.com
Thu Mar 31 10:34:50 PDT 2022
If you downloaded it from there - i think you use mapbender 3+ - than
Astrid and Jörg may help you 😉
<ihara.olivera at imm.gub.uy> schrieb am Do., 31. März 2022, 19:13:
> i'm working on windows with Apache 2.4 and php 7.4.13. I download the app
> from here https://ms4w.com/ maybe i try with the repository.
> Thank's for helping me and sorry if i bother you with this.
> ----- Mensaje original -----
> De: "Armin Retterath" <armin.retterath at vermkv.rlp.de>
> Para: "Mapbender users" <mapbender_users at lists.osgeo.org>
> Enviados: Jueves, 31 de Marzo 2022 13:52:01
> Asunto: Re: [Mapbender-users] Server Error WMS
> do you really have an old mapbender 28 installation? ;-)
> which os do you use? - we are actually under debian 11 with php 7.4 and
> postgresql 13
> we work with mapbender28 and migrate 2 years ago it to github:
> https://github.com/mrmap-community/Mapbender2.8/
> if you have any further questions, don't hesitate to ask ;-)
> best regards from germany
> armin
> > ihara.olivera at imm.gub.uy hat am 31. März 2022 18:47 geschrieben:
> > I already do this,change the variables and restart Apache but still not
> working (i have mapbender 2.8 version)
> > De: "ihara.olivera" <ihara.olivera at imm.gub.uy>
> > Para: "astrid emde" <astrid.emde at wheregroup.com>, "Mapbender users" <
> > Enviados: Jueves, 31 de Marzo 2022 13:38:30
> > Hi, how can i restart Apache?
> > De: "Astrid Emde (WhereGroup)" <astrid.emde at wheregroup.com>
> > Enviados: Jueves, 31 de Marzo 2022 12:50:37
> > Hello,
> > the service is from Montevideo Uruguay and has many layers
> http://geoserver.montevideo.gub.uy/geoserver/ows?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
> > Many layers are possible but you can not visualisize all layers at once
> > as the WMS getMap-request has a limited length.
> > You can load the WMS to the Mapbender service repository.
> > But to configure the service you have to update the php.ini of your
> > Mapbender server, as the service has so many layer that the predifined
> > configuration for php is at its limit.
> > See
> > https://doc.mapbender.org/en/faq.html
> > Increase the following variables and restart Apache
> > max_input_vars = 4000
> > memory_limit = 1024M
> > But then you also have to limit the active layers for this WMS, as with
> > all layers active you will hit the limit for the url-lenth.
> > Hope that infromation helps
> > Astrid
> > Am 2022-03-31 17:01, schrieb Jörg Thomsen:
> > > Hello Belen,
> > > looks more like a miss-configuration of the WMS.
> > > getMap:
> https://geoserver.montevideo.gub.uy/geoserver/ows?SERVICE=WMS&_signature=34%3AU4eAyyKZ-J0-25u51BfmOl2L0Hw&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image%2Fpng&TRANSPARENT=true&LAYERS=depaseo%3Atours&STYLES=&_OLSALT=0.6642019119728901&CRS=EPSG%3A25832&WIDTH=1688&HEIGHT=1191&BBOX=359697.1662468514%2C5617500%2C372452.8337531486%2C5626500
> > > results to:
> > > <ServiceExceptionReport xmlns="http://www.opengis.net/ogc"
> > > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.3.0"
> > > xsi:schemaLocation="http://www.opengis.net/ogc
> http://geoserver.montevideo.gub.uy/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd
> > > <ServiceException> The requested Style can not be used with this
> > > layer. The style specifies an attribute of horarios and the layer is:
> > > depaseo:tours </ServiceException>
> > > </ServiceExceptionReport>
> > > Jörg
> > > Am 31.03.22 um 16:39 schrieb ihara.olivera at imm.gub.uy:
> > >> To whom it may concern, i'm writing to you in order to solve a
> problem
> > >> i am recently having with mapbender.
> > >> When i try to load a WMS serivce the application throws an internal
> > >> server error and no layer is shown.
> > >> Here's the WMS
> > >> url:
> > >> And here's the error i'am having:
> > >> /I look forward to/ hearing /your reply/ asap,
> > >> best wishes,
> > >> Belen.
> > >> El presente correo electrónico y cualquier posible archivo adjunto
> > >> esta dirigido únicamente al destinatario del mismo y contiene
> > >> información que puede ser confidencial. Si Ud. no es el destinatario
> > >> correcto por favor notifique al remitente respondiendo este mensaje y
> > >> elimine inmediatamente de su sistema, el correo electrónico y los
> > >> posibles archivos adjuntos al mismo. Esta prohibida cualquier
> > >> utilización, difusión o copia de este correo electrónico por
> cualquier
> > >> persona o entidad que no sean las especificas destinatarias del
> > >> mensaje. La Intendencia de Montevideo no acepta ninguna
> > >> responsabilidad con respecto a cualquier comunicación que haya sido
> > >> emitida incumpliendo nuestra normativa municipal, así como lo
> previsto
> > >> en la Ley 18.331 de Protección de Datos Personales y la Ley 18.381 de
> > >> Acceso a la Información Publica.
> > >> This e-mail and any attachment is confidential and is intended solely
> > >> for the addressee(s). If you are not intended recipient please inform
> > >> the sender immediately, answering this e-mail and delete it as well
> as
> > >> the attached files. Any use, circulation or copy of this e-mail by
> any
> > >> person or entity that is not the specific addressee(s) is prohibited.
> > >> The City Council of Montevideo is not responsible for any
> > >> communication emitted without respecting our Organization Policy or
> > >> the Data Protection Act and Habeas Data Action No. 18.331 and the
> > >> Information Access Act N 18.381.
> > >> _______________________________________________
> > >> Mapbender_users mailing list
> > >> Mapbender_users at lists.osgeo.org
> > >> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> > > Viele Grüße,
> > > Jörg Thomsen
> > > Aufwind durch Wissen!
> > > Jetzt neu: Web-Seminare und Online-Schulungen
> > > bei der www.foss-academy.com
> > > Jörg Thomsen
> > > WhereGroup GmbH
> > > Bundesallee 23
> > > 10717 Berlin
> > > Germany
> > > Tel: +49 (0)30 / 5130 278 74
> > > Fax: +49 (0)30 / 5130 278 11
> > > joerg.thomsen at wheregroup.com
> > > www.wheregroup.com
> > > Geschäftsführer:
> > > Olaf Knopp, Peter Stamm
> > > Amtsgericht Bonn, HRB 9885
> > > Folgen Sie der WhereGroup auf twitter:
> > > http://twitter.com/WhereGroup_com
> > Mit freundlichen Grüßen
> > Astrid Emde
> > GIS-Consultant
> >    Astrid Emde
> >    WhereGroup GmbH
> >    Eifelstraße 7
> >    53119 Bonn
> >    Germany
> >    Tel: +49(0)228 90 90 38 - 22
> >    Fax: +49(0)228 90 90 38 - 11
> >    www.wheregroup.com
> >    Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
> >    Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> >    Geschäftsführer:
> > El presente correo electronico y cualquier posible archivo adjunto esta
> dirigido unicamente al destinatario del mismo y contiene informacion que
> puede ser confidencial. Si Ud. no es el destinatario correcto por favor
> notifique al remitente respondiendo este mensaje y elimine inmediatamente
> de su sistema, el correo electronico y los posibles archivos adjuntos al
> mismo. Esta prohibida cualquier utilizacion, difusion o copia de este
> correo electronico por cualquier persona o entidad que no sean las
> especificas destinatarias del mensaje. La Intendencia de Montevideo no
> acepta ninguna responsabilidad con respecto a cualquier comunicacion que
> haya sido emitida incumpliendo nuestra normativa municipal, asi como lo
> previsto en la Ley 18.331 de Proteccion de Datos Personales y la Ley 18.381
> de Acceso a la Informacion Publica.
> for the addressee(s). If you are not intended recipient please inform the
> sender immediately, answering this e-mail and delete it as well as the
> attached files. Any use, circulation or copy of this e-mail by any person
> or entity that is not the specific addressee(s) is prohibited. The City
> Council of Montevideo is not responsible for any communication emitted
> without respecting our Organization Policy or the Data Protection Act and
> Habeas Data Action No. 18.331 and the Information Access Act N 18.381.
> Im Auftrag
> Armin Retterath
> Zentrale Stelle GDI-RP
> LVermGeo Rheinland-Pfalz
> Von-Kuhl-Straße 49
> 56070 Koblenz
> Telefon 0261 492-466
> Telefax 0261 492-492
> http://www.geoportal.rlp.de
> This e-mail and any attachment is confidential and is intended solely for
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220331/4b43a172/attachment-0001.html>
More information about the Mapbender_users mailing list
