[Mapbender-users] GetFeatureInfo Problem
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Tue Sep 13 08:01:55 PDT 2022
Hello Marcin,
which version of Mapbender do you use?
F12 will give you a proper error message in the konsole / network
section. Maybe that help.
There was a problem with opening pdf. see ticket
https://github.com/mapbender/mapbender/issues/1377
See you Astrid
Am 2022-09-13 11:24, schrieb Marcin Niemyjski:
> Hello,
> I have encountered a problem:
> when connecting to the mapbender via the site address, the
> GetFeatureInfo request returns the following content:
> https://pasteboard.co/BVU46xnW29aw.png
> or throws an error in the top right corner of the screen. However, if
> I connect to mapbender via localhost, the request returns the desired
> pdf (when using firefox). In development mode, for site address,
> message is returned (for localhost status equals 200):
> https://pasteboard.co/bSm1FJT1laup.png
> I hope someone knows the solution,
> Regards, Marcin
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Tel: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220913/7ca7808c/attachment-0001.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220913/7ca7808c/attachment-0001.sig>
More information about the Mapbender_users
