[Mapbender-users] GetFeatureInfo Problem
Marcin Niemyjski mniemyjski at cloudferro.com
Wed Sep 14 07:31:42 PDT 2022
Hello Astrid,
I'm using version 3.3.1 Thanks for the tip with F12, I've managed to resolve my error with GetFeatureInfo, but I've come across another one that is somewhat similar. The search router function only works in developer mode, do you have any idea why and how I can make it work in normal state?
The console message i get:
https://pasteboard.co/JAVjPKGtfYNc.png
https://pasteboard.co/IEPlNAJsZgWk.png
As always, thank you for your help,
Marcin
From: Mapbender_users <mapbender_users-bounces at lists.osgeo.org> on behalf of Astrid Emde (WhereGroup) <astrid.emde at wheregroup.com>
Sent: Tuesday, September 13, 2022 5:01 PM
To: Mapbender User List <mapbender_users at lists.osgeo.org>
Subject: Re: [Mapbender-users] GetFeatureInfo Problem
Hello Marcin,
which version of Mapbender do you use?
F12 will give you a proper error message in the konsole / network
section. Maybe that help.
There was a problem with opening pdf. see ticket
https://github.com/mapbender/mapbender/issues/1377
See you Astrid
Am 2022-09-13 11:24, schrieb Marcin Niemyjski:
> Hello,
>  I have encountered a problem:
>  when connecting to the mapbender via the site address, the
> GetFeatureInfo request returns the following content:
>  https://pasteboard.co/BVU46xnW29aw.png
>  or throws an error in the top right corner of the screen. However, if
> I connect to mapbender via localhost, the request returns the desired
> pdf (when using firefox). In development mode, for site address,
> message is returned (for localhost status equals 200):
>  https://pasteboard.co/bSm1FJT1laup.png
>  I hope someone knows the solution,
> Regards, Marcin
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei der www.foss-academy.com<http://www.foss-academy.com>
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Tel: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com<http://www.wheregroup.com>
   Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
   Folgen Sie der WhereGroup auf twitter:
   http://twitter.com/WhereGroup_com
   Geschäftsführer:
   Olaf Knopp, Peter Stamm
   Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220914/8b76db94/attachment.htm>
More information about the Mapbender_users mailing list
