[Mapbender-users] GetFeatureInfo Problem
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Wed Sep 14 22:50:43 PDT 2022
Hello Marcin,
in most cases it is the cache that has to be deleted to make the search
work in prod mode. If it already works in dev -mode.
Please keep in mind that pro mode reads from the cache files. So makebe
the cache docs not provide the database connection info from
parameters.yml and config.yml.
See you Astrid
Am 2022-09-14 16:31, schrieb Marcin Niemyjski:
> Hello Astrid,
> I'm using version 3.3.1 Thanks for the tip with F12, I've managed to
> resolve my error with GetFeatureInfo, but I've come across another one
> that is somewhat similar. The search router function only works in
> developer mode, do you have any idea why and how I can make it work in
> normal state?
> The console message i get:
> https://pasteboard.co/JAVjPKGtfYNc.png
> https://pasteboard.co/IEPlNAJsZgWk.png
> As always, thank you for your help,
> Marcin
> From: Mapbender_users <mapbender_users-bounces at lists.osgeo.org> on
> behalf of Astrid Emde (WhereGroup) <astrid.emde at wheregroup.com>
> Sent: Tuesday, September 13, 2022 5:01 PM
> To: Mapbender User List <mapbender_users at lists.osgeo.org>
> Subject: Re: [Mapbender-users] GetFeatureInfo Problem
> Hello Marcin,
> which version of Mapbender do you use?
> F12 will give you a proper error message in the konsole / network
> section. Maybe that help.
> There was a problem with opening pdf. see ticket
> https://github.com/mapbender/mapbender/issues/1377
> See you Astrid
> Am 2022-09-13 11:24, schrieb Marcin Niemyjski:
>> Hello,
>> I have encountered a problem:
>> when connecting to the mapbender via the site address, the
>> GetFeatureInfo request returns the following content:
>> https://pasteboard.co/BVU46xnW29aw.png
>> or throws an error in the top right corner of the screen. However,
> if
>> I connect to mapbender via localhost, the request returns the
> desired
>> pdf (when using firefox). In development mode, for site address,
>> message is returned (for localhost status equals 200):
>> https://pasteboard.co/bSm1FJT1laup.png
>> I hope someone knows the solution,
>> Regards, Marcin
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users [1]
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Aufwind durch Wissen!
> Jetzt neu: Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com [2]
> Astrid Emde
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> Tel: +49(0)228 90 90 38 - 22
> Fax: +49(0)228 90 90 38 - 11
> www.wheregroup.com [3]
> Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Links:
> [1] https://lists.osgeo.org/mailman/listinfo/mapbender_users
> [2] http://www.foss-academy.com
> [3] http://www.wheregroup.com
Astrid Emde
GIS-Consultant
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
www.wheregroup.com
Geschäftsführer:
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220915/2f79d619/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220915/2f79d619/attachment.sig>
More information about the Mapbender_users
